<div class="bbWrapper"><blockquote data-attributes="member: 27705" data-quote="Speed3.5" data-source="post: 6828882"
class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
<div class="bbCodeBlock-title">
<a href="/forum/goto/post?id=6828882"
class="bbCodeBlock-sourceJump"
rel="nofollow"
data-xf-click="attribution"
data-content-selector="#post-6828882">Speed3.5 said:</a>
</div>
<div class="bbCodeBlock-content">
<div class="bbCodeBlock-expandContent js-expandContent ">
I’ve gotten 40’ish mpg on some long drives as well(6-10hr), same oil brand/type/oci. I made the call since the beginning to do frequent oci with affordable oil & filter given the driving the Mazda 3 does.<br />
<br />
Next factor would be location weather, I haven’t checked the parameters during the summer yet but now with colder temps in NJ the engine oil stays below 200.<br />
<br />
My suggestion is to move up to 5w30 since you do more HW miles and have higher miles, you’ll see some benefit of 30 vs 20 weight oil.<br />
<br />
Fluid management is key especially when you accumulate miles fast.<br />
<br />
I plan to switch next summer to 5w30 Synthetic as the car will be over 100k miles.
</div>
<div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div>
</div>
</blockquote><br />
The weather has cooled down quite a bit in the last few weeks. I notice that the coolant temp stays the same while the ATF temp seems lower.<br />
<br />
I understand your reasoning behind the short OCI. I may have used SupertTech's dino oil or two stroke oil in the past, can't remember which. I don't mind changing the oil/filter every 3 to 4 months, but every two months would be a bit much. <img class="smilie smilie--emoji" alt="😂" src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f602.png" title="Face with tears of joy :joy:" data-shortname=":joy:" loading="lazy" width="64" height="64" /> <br />
<br />
I accumulated 15+ jugs of dirty oil from all my cars in the last few years. I use the oil to stain the fence, 2x4s, patio furniture, and wood puzzles. In my area, each facility can only take 5 jugs per day, so I went to O'Reilly, then AutoZone, and finally the local recycling center. For the first two, they gave the almost empty jugs back to me. I had to drain them more fully at home before sending the jugs to the recycling center. It was a lot of work.</div>
