OBD2 Scanner/App: what sensors/values to monitor?
What's your oil temperature? Mine is NA and today it went up to 224 at one point during a long drive.
What's your engine OCI and what weight do you use.
In my case atx and engine oil temps are close to each other.
I change engine oil every 3.5k/4mo SuperTech 0W20 Full Synth as it does more short drives around the town (35%hw/65%local).
Record some data and share it if you can.
Currently between 7K and 8K miles. Had a sample analysis done a few years ago and was told that I could go longer. Rarely had to top off in between. I drive 2K+ miles per month and 90% freeway. Been using all major brands of 0w20 full synth around $30. Tried 5w30 once and didn't notice any difference back then. For my current and last round, Royal Purple 0w20 and the mpg has gone up significantly. I was happy at first but then I wonder how thin must it be to achieve mpg higher (35 to 40) than what the factory intended (27/32/29 let's call it 30)? What kind of friction modifier in there works better than LM's formula as an additive (have added that in the past)? Will collect a sample for this round for sure. Can someone else try RP and see what happens?
The plan is to switch to 5w30 and oem filter next. The oil temp is typically 210 for an hour-long drive and over 220 on long drives. ATF temp stays below 200 unless on steep inclines. Coolant temp can be as high as 214 in stop and go traffic. Did you mean using the app to log some data?
This is for my weekly 150 mile drive that takes 2.5 to 3 hours. The point where the ATF and oil temp peaked was one hour in and at the steep incline over 152 West.
This is from yesterday with the car parked for about half an hour (usps) and then two hours (labwork) in between. Engine oil temp is not read when the ignition is off.
I’ve gotten 40’ish mpg on some long drives as well(6-10hr), same oil brand/type/oci. I made the call since the beginning to do frequent oci with affordable oil & filter given the driving the Mazda 3 does.
Next factor would be location weather, I haven’t checked the parameters during the summer yet but now with colder temps in NJ the engine oil stays below 200.
My suggestion is to move up to 5w30 since you do more HW miles and have higher miles, you’ll see some benefit of 30 vs 20 weight oil.
Fluid management is key especially when you accumulate miles fast.
I plan to switch next summer to 5w30 Synthetic as the car will be over 100k miles.
Does anyone know how to get Torque Pro to display transmission fluid temperature for my 2nd gen CX-9? I'm using a ELM327 Bluetooth OBD2 adapter and the paid Torque Pro app for Android. The only value I can find for transmission fluid temperature shows no data.
I have Torque Pro. Let me check... On the same phone with the same adapter, the Torque Pro app doesn't show any reading for the engine oil temp or "transmission temp (method 2)". 🤦
Try the free app obd2 car reader that does show those parameters.
Haven’t tried Torque Pro.
