Ok guys. I have the base models done and fitted, so I can do any kind of panel you want as far as layout. All panels will be cut from high grade stainless steel unless otherwise requested. Each panel will be provided in an unfinished state so you can brush, polish, or paint as you desire.
Here is the pricing: (This may fluctuate due to the insane steel prices right now, but should stay close on these prices)
Single DIN (CD Pocket replacement):
1-3 panels of design: $85/ea
5-8 panels of design: $72/ea
9-19 panels of design: $60/ea
20+ $50/ea
Double DIN (Radio and CD Pocket Replacement)
1-3 panels of design: $90/ea
5-8 panels of design: $75/ea
9-19 panels of design: $65/ea
20+: $53/ea
So it is in your best interest to to get more people together on the panels. Also, this is the preliminary pricing. I may be able to cut about 10-15 dollars off some of the pricing in the case of some designs. So please let me know what you'd like and I'll happily get going on them for you guys. You can see some samples of the work at www.nsnmotorsports.com in the products area.
Some example design possibilities:
Single DIN with 3 52mm gauges
Single DIN with 2 52mm gauges and MSP or MP3 or P5 logoing
Single DIN with 1 52mm guage, auxillary switch, and 2 Greddy TT/EBC slots
Double DIN with 4 60mm gauges
Double DIN with 2 60 mm Gauges and 3 52mm gauges
ETC.. These will be laser cut so the finish is perfect, the metal doesn't get scratched from clamping, and complex curves and shapes can easily be done!
So let me know what you want. Lead time on first run designs will be about 2.5 weeks or less.
Thanks!
Steve
NSN Motorsports
20+ $50/ea
20+: $53/ea
Thanks!
Steve
NSN Motorsports
