Exactly what I dreampt up an executed in '03. (birthday)KzA said:yea....This whole MAP thing is really getttin me curious..it sounds like its good for the application, since the desired result is for it to drive stock before boost..
Not if you are tuning right. You would set the load fuel 1x16 to not add fuel under light loads. Also you need to calibrate the sensors. If you max out the airflow with your MAF you need a bigger one. Going to a three bar MAP will not get you more air.Kooldino said:Until you max out your MAF...and then you either need a bigger MAF or a MAP sensor.
My problem with MAF tuning is that it would see the same amount of air at say... 3000rpm @ 4psi as it would at 5500rpm at 0psi. So it would add fuel in the latter case, where it should not be adding fuel. With the MAP sensor, I set it to turn on at ~1.85v or so (or at least that's what I had LinuxRacr do...I think mine is set to that voltage), which the MAP sees as 1psi...at which point it starts using my extra injectors.
SO it's not the MPI. Maybe the 02 sensor is defective on the car ?LinuxRacr said:Something else is wrong with my car... It still leans out. I need to check some wiring, and sensors. Every since I hooked the MAF back to stock, I keep throwing the same CEL code: P0171 (Bank one too lean), even though the wideband says I'm at 14's A/F ratio at idle, or cruising. WTF??
How bout those injectors, did you ever get them cleaned right? I mean not just dumping cleaner in your tank.LinuxRacr said:(mswerd)
I have over 120,000 miles on the chasis. Engine-wise, the car is still relatively young.![]()
Cars suck, and the more power you try to make the harder it is to ge there.LinuxRacr said:Something else is wrong with my car... It still leans out. I need to check some wiring, and sensors. Every since I hooked the MAF back to stock, I keep throwing the same CEL code: P0171 (Bank one too lean), even though the wideband says I'm at 14's A/F ratio at idle, or cruising. WTF??
I did. But I still ran into the issue in certain cases. That's the problem with a MAF.MPNick said:Not if you are tuning right. You would set the load fuel 1x16 to not add fuel under light loads.
They're calibrated within 1/100 of a volt.Also you need to calibrate the sensors.
No, but it will tell me how much boost I'm running and it will make it more drivable and easier to tune.If you max out the airflow with your MAF you need a bigger one. Going to a three bar MAP will not get you more air.
I know how to MAF tune, and I've done it with other EM systems that are more well set up to do so without issues. To fine tune with a MAF, you need more resolution on the fuel map than the SMT-6 has. Other EM systems have very high resoultion maps for a reason.Air flow is air flow, that is what the MAF is reading. If you do not know how to tune right with the MAF
Do you have an FM clamp? Is it hooked up right?LinuxRacr said:Something else is wrong with my car... It still leans out. I need to check some wiring, and sensors. Every since I hooked the MAF back to stock, I keep throwing the same CEL code: P0171 (Bank one too lean), even though the wideband says I'm at 14's A/F ratio at idle, or cruising. WTF??
You're kidding me, right? His car is RUNNING, and RUNNING WELL (off of boost, anyway). He's running 14's in the AFR off of boost. He just has a CEL. It's still RUNNING smoother than it did when he didn't have the MAP sensor. Granted he may still have issues somewhere, but at least it's more drivable even in that condition.MPNick said:Cars suck, and the more power you try to make the harder it is to ge there.
I see again that it was not do to the MPI Tuner or they way we feel it should be set up and tuned.
Yes he still has issues, are you a nuts.Kooldino said:Granted he may still have issues somewhere, but at least it's more drivable even in that condition.
No you do not know how to tune the stock MAF, thats why you are not doing it that way. What the hell do you not understand? People are tuning the stock MAF everyday on the forum. You could not because you do not know what you are doing. Are these people thinking they are tuning the MAF, but they are not? You keep making post's about why you cannot do it but you just do not understand. Mazda Protge forum members are tuning the stcok and my aftermarkt MAF all day long. You cannot say it cannot be done it is being done. Stop saying it cannot be done it is, every ******* day.Kooldino said:I know how to MAF tune, and I've done it with other EM systems that are more well set up to do so without issues. To fine tune with a MAF, you need more resolution on the fuel map than the SMT-6 has. Other EM systems have very high resoultion maps for a reason.
Yes, I am a nuts.MPNick said:Yes he still has issues, are you a nuts.
Then what's wrong with his car? Wasn't he running ok when he had an FMU, before he put the MPI in?How in hell is he going to tune around problems? He needs to fix his car.
I agree.You just do not get it, do you. If the car is not right you cannot tune it right.
Again, my way is just simpler, and people have less problems with the actual tuning. That's all.So what you are trying to prove is you way is better for cars that are not running right. Your way is better? Please keep making posts like this, you are proving me right more and more.
