It is much better at reading total air flow then a MAP ever was, is or will be.Dexter said:can you explain why MAF is better?
I have seen where these cars do not like to have timing added at idle. After that adding some timing does help, but I do not like to add timing under boost. What kind of AFRs are you running at boost tip in?igdrasil said:Well, the MPI was a bit rough on the timing side while out of boost if no modification is done (0 on timing), I thought that it could be a lag issue, so i started to add timing whenever he was out of boost and all went pretty smooth...no more bumpy 3krpms
On the downside, in my case I had noticeable pinging (ugly) while applying load on very low rpms and out of boost, sometimes while building the first 8psi's...maybe because too much timing advance was still there, some pinging was noticeable. Pulled 1 more degree off the boost retard down low and done.
Then if you try to start retarding too soon, low end torque is killed. And if you try to settle (0 timing advance or retard) on the boost threshold, you go into the bumpy threshold, its very minimal, but I think thats what we all refer.
Looks like a bit of timing advance is needed to keep up to the first 1-3psi to make a smooth power pickup, but you may experice some ping if you PUNCH IT and still have some advancing or no retard with a lot of boost.
Im not quite sure about the A/F, but with the vortech 12:1 right now, is just a bit lean because i had to pull some fuel out on some areas where the vortech adds too much, some that may be a threshold on some situations, but now im pulling -2 as the 1st psi comes.MPNick said:I have seen where these cars do not like to have timing added at idle. After that adding some timing does help, but I do not like to add timing under boost. What kind of AFRs are you running at boost tip in?
12 is not lean at 1 psi. It is very rich.igdrasil said:Im not quite sure about the A/F, but with the vortech 12:1 right now, is just a bit lean because i had to pull some fuel out on some areas where the vortech adds too much, some that may be a threshold on some situations, but now im pulling -2 as the 1st psi comes.
I don't think that's his A/F ratio. That is the ratio on his Vortech FMU he is running...MPNick said:12 is not lean at 1 psi. It is very rich.
yeah 12:1 Vortech calibration.StuttersC said:I don't think that's his A/F ratio. That is the ratio on his Vortech FMU he is running...
Nope..the easiest..way..is to live close to MPI Nick..(like i do)..and have him help/tune my car!Kooldino said:(second) Glad to see you took my advice from over a year ago.Simple to tune this way, isn't it? Hopefully more people will start listening to me about it now. The easiest way to use the MPI tuner is...
-with an FM clamp
-with extra injectors, controlling only those injectors
-with a MAP sensor to sense boost
-to retard timing where necessar
-with a FCD, if necessary
Happy tuning.
So what's the better way to tune with it, how bout some elaboration????MPNick said:The MPI is only doing what it was tuned to do. If it was fighting out of boost it was tuned wrong. If you are only adding fuel with the extra injectors under boost only that sounds right. But you could have done the same with the MAF. You do not need the MAP to do that.
If you still think the MAP is better for you there is a better way to use it then you are now.
You can do that right now without use a MAP. You just need to move some wires.KzA said:yea....This whole MAP thing is really getttin me curious..it sounds like its good for the application, since the desired result is for it to drive stock before boost..
OKBigg Tim said:So what's the better way to tune with it, how bout some elaboration????
SOOOOOOO......where's it at?MPNick said:
Yes sir. Been that way for the past 14 months now.StuttersC said:Interesting...
So, you use the MPI to run the extra injectors and use the MAP to tell the MPI when to come on? Leave the stock injectors to be run by the ECU, and change timing with the MPI too.
It's simple, and it works. I have no experience with the turbo module, and I have no reason to use it.Why is the FM clamp better than the turbo module?
There's tons of $300 injector controllers out there. Just not sure if they can retard timing in OUR cars.Now, my other question is what other devices can run extra injectors in a similar manner that aren't as expensive?
I see a lot of people having tuning issues with the MPI, and I frequently see you blaming it on the person doing the tuning. Regardless if it's the person's fault or not, the MAP + extra injector way is easy for everyone to tune, and that's why I endorse it. It's simple, and it works. (cool)MPNick said:The MPI is only doing what it was tuned to do. If it was fighting out of boost it was tuned wrong. If you are only adding fuel with the extra injectors under boost only that sounds right. But you could have done the same with the MAF. You do not need the MAP to do that.
Until you max out your MAF...and then you either need a bigger MAF or a MAP sensor.MPNick said:It is much better at reading total air flow then a MAP ever was, is or will be.
TruthMPNick said:12 is not lean at 1 psi. It is very rich.
12:1 on the Votech is RICHER than 12:1 AFR, In my experience.igdrasil said:yeah 12:1 Vortech calibration.
This always creates confusion.
Until something goes awry and you don't know how to fix it yourself. (sick)acidbbg said:Nope..the easiest..way..is to live close to MPI Nick..(like i do)..and have him help/tune my car!
