Hi!
Protege5 with check engine light on due to Bank1 lower than treshold but no more consumption than before. I kept it like that for more than 2 years before I decided to try the Non Fowler Trick. The check engine went off. Then, it started to drink like crazy. I've tried to reduce the Non Fowler extension, still, the same problem and the check engine stayed off. I completely removed the Non Fowler; The check engine came back (I was almost happy) but after a quarter of a tank and 65 klits I have to say the problem is there more than ever.
Is someone has an idea what has been going on and how to solve it in the cheepest way? (Note I had to use a bit the torch to unscrew the sensor... The one after the horizotal catalyst). My catalyst is jammed I'm pretty sure cause 2 years ago I had random missfires.
Is a cheep catback could solve this?
Thx!
Yanos3000
Thx!
Yanos3000
