7300 on the tachometer or real rpms? ~7300 on the tacho are about 7000.
I said Z6, not ZM. They are related but not the same generation engine
ZY(1.5) and Z6(1.6) have identical heads(and depending at the production year they may even have the same camshafts). To sum up, the head(including valves,springs,retainers,cotters etc),  have the same p/n
Here is a video back in 2010 i think. 7350 revlimit
https://youtu.be/DLDfng5WK00
The same noise. After inspection the noise was coming from the valve train under the valve cover.
I was running 7300 for 3 months. My valve clearance was going off(upper limits).
Look, I am not trying to judge or to say anything about the mapping, but because I've been there and done that I am trying to help everybody(as I always do). If you believe that I am wrong, fine by me, just please take my advice into consideration. That's all.
8000rpm with stiffer springs and offcourse without that noise.
https://www.youtube.com/watch?v=_Y-OEZegHOg
8000rpm with a spring rated 59lbs at 27.5mm(that is at maximum lift) ?
That's a Good one.
