You need the enhanced diagnostics to display things like individual tire pressures, short and long-term fuel trims and hundreds of other PID'sSharing, apparent update to OBD Fusion added enhanced diagnostics for Mazda 2025 and 2026. Not sure what this update entails. Maybe someone else already knows what is on the update for Mazda owners?
That's very neat! Does it show a second coolant temp value?You need the enhanced diagnostics to display things like individual tire pressures, short and long-term fuel trims and hundreds of other PID's
... - On the original KE CX-5 AWD system, when I am on normal, everyday driving, am I being 100/0 or 98/2 or 95/5 or something? ..m
The enhanced diagnostics aren't needed to see the second coolant temp value as two coolant temp values are included in the standard ODBII data points.That's very neat! Does it show a second coolant temp value?
Thank you that's good to know!The enhanced diagnostics aren't needed to see the second coolant temp value as two coolant temp values are included in the standard ODBII data points.
It won't stay steady, the solenoid is very active constantly adjusting torque split.Thank you that's good to know!
The only 4WD related sensor I found in the Car Scanner Pro app is the coupling solenoid duty cycle with a % value. It was fluctuating between 1% and 14% for the most part of my 2-hr drive this morning. It never showed a steady value.![]()
