- Plano, Texas, USA
If the problem is caused by a damaged bearing in the transaxle due to improper configuration of the transaxle case, this means the bearing eventually will wear out and get damaged unless you have a corrected transaxle case. It's just a matter of time.EDIT: IMO... I don't believe this is a widespread problem but obviously there are some out there.
It would be nice to know a little more background on the TSB. Questionable parts supplier, predominantly city driving, towing, fluid changes help, etc? I think of any car component I am most sensitive to transmissions. I had a failure as a kid at a time when I could least afford the repair.
Here is a little pricing info for out of pocket.
http://www.jimellismazdaparts.com/p...MATIC-TRANSMISSION-4WD/9903278/FW7A03000.html
$2760 with a $1K core charge + $250 shipping
No idea what the book rate for install on this is
Seriously, I feel automatic transmissions are more reliable nowadays. I've seen many auto trannies needed to be overhauled at 50,000 miles in the old days. Many years ago I overhauled a Borg Warner automatic transmission from my old '72 Mercury Capri which had only 45,000 miles. That is the extreme of my many DIY projects and I imagine that is also my last DIY work to overhaul an automatic transmission.
