Well I have taken a few days to brainstorm and work with the engineer at Mishimoto on the suggestions/requests made.
First off, I would like to say that it was never our intention with this project to have as stated in a previous post here.... " at this rate, it's looking like MSP owners are screwed again"
I really appreciate everyones comments, suggestions, and input but when it comes in that form it is really not beneficial for anyone!
Second, the intention as stated from the start was to get for our market a performance radaitor that was of reasonable quality at a more reasonable cost than currently available. This required contacting and negotiating with several companies due to the relatively small market of the Protege let alone the even smaller market of the MSP.
So with those thoughts in mind I have attempted to come up with some ways to possibly make this work for as many as possible.
The passenger side (US) MSP radiator fan is similar in mounting on the top side to the sedan fan. The main difference is that the pointed locating lug on the bottom is longer. Rather than making those who wish to use this fan alter the fan I think an extra tab can be welded to the radiator. However, it will be directly below the tab for the sedan fan so when installing the radiator one of the tabs will need to be cut off.
As for the driver side (US) MSP fan, the fan runs into clearance issues with the water inlet. It seems as though it should be a simple solution to just change the palcement of the water inlet but with the cost constraints on this project it is not possible. Therefore, even though I have tried several means to get something to work for this fan I don't think it will be possible. The radiator will be set up to use the sedan/P5/MP3 driver side fan. If you determine it is necessary to have this fan several of these are available used on this forum very inexpensively.
Regarding the request to have the radiator mount so that the top of the tank is flush, that may be possible. However, the radiator dimensions are going to stay at those mentioned early on in the thread. The best way I have determined to make the radiator mounting similar to the MSP would be to provide extra long lugs on the bottom of the radiator and spacers that will allow the radiator to move up in the mounts to near the hieght of the MSP radiator. Once a prototype is received I can determine this further. My hope is that this will allow use of either the MSP mounting location and brackets or the sedan/P5 mounting location and brackets by simply using or not using some supplied spacers. If this is determined to be possible it may add some extra cost to the radiator.
I hope that our efforts in this project are appreciated??
I am open your thoughts on the ideas submitted to make as many Protege owners able to use this product as possible.
I am concerned that if a resolved consensus is not reached soon and the last few needed deposits are not received it may be a moot point....
