I have researched the options that have been discussed.
Regarding the radiator height. If the rad is made to sit flush or basically MSP height all non-MSP owners will need to replace their upper radiator brackets with the flat MSP versions. Mazda currently sells these for $42/each and there are only 11 (not even enough for six sets!) available in the US.
Obviously, this will not work.
If the radaitor is made sedan/P5/MP3 height, only MSP owners will need to purchase upper radiator brackets. They are available from Mazda for $12/each and several more are available (besides the large used market from salvage/used part sales).
Also, speaking with the engineer the slight increase in height would give very minimal increase in cooling capacity since the core and end tanks are already considerably thicker than the OE radiator's.
Let me know your thoughts.....
I think Edwin's point is more about efficiency rather than capacity - as these have much more capacity than stock. The way I see it is if the radiator was taller more air would pass over the core, rather than the top tank. There would also possibly be a benefit in that there would be less air flowing in between the gap between the top tank and the radiator support bar and perhaps going "around" the radiator.
Is there a major cost issue with making brackets that could be used by everyone? They are basically a flat bit of metal with some holes drilled in them. I for one, would pay a bit extra for brackets.
