New Exhaust for Mazdaspeed Proteges
Check this out guys the people that make our exhaust are awsome.
Hi Adam
We would be happy to send you some stickers and other goodies for your car at no charge.
Send us your address and we'll send you whatever we've got in stock.
Send us a photo of the exhaust on your car...maybe we can use it in our advertising.
Thanks
Dino Rossi
Vibrant Performance
www.vibrantperformance.com
-----Original Message-----
From: adam james [mailto:mazdaspeedguy99@yahoo.com]
Sent: Monday, February 21, 2005 2:50 PM
To: Dino Jr. Rossi
Subject: Your decals and other novalty items.
Hello,
I just recently purchased your s-back exhaust for my Mazdaspeed protege which I recently installed on to my car. I am now a huge fan and I would like to know how I can order your decals to put onto my car as well as your exhaust keychain? Can I order them directly from you or do I need to contact one of your vendors? I would also like to thank you guys for making such a awsome exhaust for my car I truly love it.
thanks
adam james
Hi Adam
Thanks
Dino Rossi
Vibrant Performance
To: Dino Jr. Rossi
Hello,
thanks
adam james
hey thats awsome, do you mind if I follow you with an email to them, if it bothers you i wont, but then i totally expect you to mail me something. Scott
do you guys have CEL after putting in the exhaust? I reseted my ecu, and after 50 kms or so, CEL comes up again. What caused this problem? I didn't install the exhaust. Did the guy screwed up the o2 sensor?
AlexTheBum said:
Make sure you have the black wires with black and blue connected.
here guys here's a clip of the exhuast :)
http://home.comcast.net/~s4dawgs/PICT0370.AVI
Alex, thats so funny, i was watching your vid clip and it is actually like mine! i mean exactly. same angle and you can see a reflection of me walk to start the car, you see the car dip when i sit in it and start the car, the sound card is messed up on my comp, so i couldnt hear what you did, but if you did a little rev, then we really have the same exact vid, just my car is silver, yours is blue. how do i get my vid on here? the same angle trips me out.
even my cat loves vibrant performance!
I have a question. Why do we have to rewire the o2 sensor? If the reason is to have it behind the cat then what do people without them do.
Yes, you will have to extend the wiring for the O2 sensor so that the sensor can be placed behind the cat. People that are running catless exhaust are using MIL Eliminators or some other method to get around the CEL. A catless exhaust will not pass emissions in most states.
maybe they didnt extend the wires to the second hole, they could have used the first one and you would throw a cel. Have you gotten under to look at it.
I did a super clean job on my wires, after the heat seal butt conectors i used shrink wrap over them then electrical tape around the whole bundle then plastic protec sleeve over that. i am not taking any chances.
also if you disconect the wires from the engine bay and do it at a work bench it is much easier, there's a bracket that you can get to from the top between the block and the firewall more on the passenger side, disconnect the male-female plug and then remove the old dp cat section, pull that out and remove the o2 sensor, BE CAREFUL NOT TO TOUCH THE SENSOR!!!!, work on it then put the new pipe in position, turn it facing you and install the o2 sensor, install the pipe then reconnect the wire at the top. easy peasy japanesy.
Mine should be going on the dyno later this week. I put down 152hp 158tq with the sp2 being my only mod last friday.
Had you baselined it before you put the SP2 on?
Alex
that sounds about right for an all stock car
