KpaBap said:also, upgrading from a 2500+ to a 3.0 ghz P4 is not worthwhile IMO, it will be only marginally faster 99% of the time
Matthew said:i just bought another 512mb pc3200 ram. guess it was faster than i tought...are those temps ok?
Matthew said:if my temps are ok, why bother? i will clean eveyrthing out though for sure.
what about those ram coolers (prolly worthless) etc etc?
this is the case i bought (nothing fancy):
http://www.xoxide.com/xoxide-iron-deux-case.html
your thoughts on the best way to keep it cool (if any more so than i am right now) are appreciated. also some of the things i could get from:
www.1coolpc.com
i used to shop there before when it was called 3dfxcool or something. anyhow, let me knwo if there is anything from there or anything else you suggest...
KpaBap said:I would put as many fans as you possibly could, I have 2 intake fans on the front of the case blowing over the hard drives, one on the side panel blowing directly over the CPUs and on the back panel I have 2 exhaust fans and the PSU has 3 exhaust fans
anyway, the CPUs hardly hit 102F under full load, these are 2 XP 2400s, so your 120s are a bit on the high side
Matthew said:ok i know i have a really cheap motherboard, is it worth upgrading THAT while im taking s*** apart? im not using raid or whatever and for some reason i just cant see the differences between some ofhte more expensive boards and the one i have...
Biostar USA
Matthew said:ok cool. did you see that little duct system they have on 1coolpc? is that worth it? i just get concerned sometimes because i leave the computer on all day...
anything else you suggest (since im on a buying binge this weekend)?
