Threw the alternator belt, then the battery went, and now with the new battery, all it does is click and smoke comes off the terminal.
I hate to ask but are you sure you have the correct terminals attached?
Eh... roads were wet and had some salt on them. Kinda... not ideal.
Ideal for making you cry...
I asked myself the same thing. I double checked like 4 times. Used the multimeter to make sure that the way it's connected reads > +12V. All the lights and stuff work, including the HIDs. If those were hooked up backwards they wouldn't. I'm going to take the starter off tonight and get it tested.
How easy is it to take the starter off? Looks like a pain in the ass to get to
All starters are easy... except that 1 single bolt that takes exactly 1 hour.. 3 bloody knuckles and 2 thrown wrenches to get out.
Dont let Luke 'pencil' you in... or he'll cancel... make sure its in PEN!
12"x12" marble tiles.What size tile?
Are you renting the tile saw for a day or do I need to hand cut all the tile?
Check price, pre-mixed is a little easier, but more expensive. might be okay with the small area.
You'll need tiles, mortar, grout, spacers, a couple large sponges and a couple buckets.
Whats the subfloor look like? Is it all clean, smooth and screwed down well?
