Need help on install
i got one installed on my car.. took literally 15-20 minutes. jack up the car ( make sure its safe) and right behind the gas tank, facing front of the car, you will have your control arms, and one bolt on each side, i think its a 17mm if im not mistaken, take them out, put the bar on, and put everything back together. the shorter side of the tie bar has to be on passender side
