Nav/Infotainment system hack to open up optins while moving?
BDIZ
2016 6 gt
Anybody have any info if there is some sort of hack to open up the options that are blocked while the car is moving?
Sucks that you can't enter new Nav destination while driving.
With my Dodge there was a lockpick interface that opened up restricted options.
This is the one thing I really dislike on the car too. There was an old hack for the oler Mazda3 but I don't think anyone has tried it on the newer 6
Sent from my iPad using Tapatalk
I got it to work ! Takes some computer work but not much. I followed the instructions for getting into the use port with a Belkin F5D5055 usb to Ethernet adaptor and from http://forum.mazda6club.com/car-ele...ks.html#/forumsite/20967/topics/351338?page=1 (don't follow the guys saying to cut a wire. This is dumb and not needed. ) then I didn't edit the file like he said but did the Mazda 3 hack from http://mazda3revolution.com/forums/...ent.html#/forumsite/20910/topics/64858?page=1.
Sent from my iPhone using Tapatalk
Your a Life Saver
You have saved me from gouging my eyes out from the irritation of not being able to use all features. THANK YOU SO MUCH. just got my 2016 last week and love everything about it except that.
I copied this from another thread from member Chemisus ....
2016 Mazda6 GT owner, and software developer here. You absolutely do not need to snip any wires to disable the speed restrictions on a 2016 Mazda6. What you do need is a way to SSH into the computer. The items needed to gain access are as follows:
- USB ethernet adaptor
- cat5/6 cable
- network router
- laptop with ssh (PuTTY if you're on windows)
- recommended: power inverter car capable of supplying power to router
Quick Steps:
1. plug usb ethernet adaptor into car's usb
2. run ethernet cable from usb adaptor to router
3. plug router into power inverter
4. plug power inverter into the slot in center console (it continues to supply power after engine is turned off)
5. turn on car
6. connect laptop to router (wireless is fine)
7. confirm that the car is establishing a connection with the router.
8. obtain ip address of car.
9. ssh into car with username of root.
10. password should be jci
11. once in, mount drive in write mode with "mount -o rw,remount /"
12. edit /jci/scripts/set_lvds_speed_restriction_config.sh with vi
From here I did what I found for Mazda 3 hack from user Zombiejunkie.
13. Type in: /jci/scripts/set_lvds_speed_restriction_config.sh disable 14. If done correctly it should say that it is disabled. 15. Type in: /jci/scripts/set_speed_restriction_config.sh disable 16. If done correctly it should say that it is disabled. 17. Turn your car off. 18. Exit out of the app or program.
Expanding:
Usually a light on the router that represents the port the cable is plugged into will be on. I did this while sitting in the parking lot at nearest best buy, ended up exchanging twice, third one (and cheapest) worked.
There are a few different ways this can be done. Most common methods are either ip scans, logging into the router via web browser and checking dhcp tables, or even simply trying to guess by ping. IIRC the dhcp tables will have a blank name for the car. Chances are the car will have an ip address of 192.168.1.X where X is 100 or slightly higher.
With car ip of 192.168.1.101, on mac and linux, command would be "ssh root@192.168.1.101". I don't remember how PuTTY does it, but I think you provide username and ip address in separate fields.
12 & 15 editing
vi (yes, that is the name of the program) is the only editor on the disk. It's not as easy to use as vim (vi improved). A real simplified description of vi would be: it has two modes; command, and edit. vi starts off by default in command mode.
- To exit command mode, and enter edit mode, hit i.
- To exit edit mode and return to command mode, hit escape.
