I prefer to spend the few bucks more and get the real Moly Mazda oil. We are talking
maybe $15 more per oil change. That's chump change on $30k vehicle. Moly prevents carbon buildup which is very common on direct injection engines like the SkyActv.
MOLYBDENUM: (from Bob the Oil Guy)
http://www.bobistheoilguy.com/applications-for-lubrication/
A single molecule of Moly contains two sulfur atoms and one molybdenum atom. Moly platelets are attracted to metal surfaces. This attraction and the force of moving engine parts rubbing across one another provide the necessary thermochemical reaction necessary for Moly to form an overlapping protective coating like armor on all of your engine parts. This protective armor coating has a number of properties that are very beneficial for your engine.
The Moly platelets that make up the protective layers on your engine surfaces slide across one another very easily. Instead of metal rubbing against metal, you have Moly platelets moving across one another protecting and lubricating the metal engine parts.
This coating effectively fills in the microscopic pores that cover the surface of all engine parts, making them smoother. This feature is important in providing an effective seal on the combustion chamber. By filling in the craters and pores Moly improves this seal allowing for more efficient combustion and engine performance.
This overlapping coating of Moly also gives protection against loading (perpendicular) forces. These forces occur on the bearings, and lifters. The high pressures that occur between these moving parts tend to squeeze normal lubricants out.
Eventually, there is metal to metal contact, which damages these moving parts and creates large amounts of heat. Fortunately, this is not the case with some lubricants.The layer of moly that forms on these moving surfaces can
withstand pressures of 500,000 psi, without being squeezed out.
Since that time theproduct has undergone extensive independent testing in labs and in the field for many years to insure that the product stands up to the rigorous needs of todays engines. With the plating action of Moly reducing friction which reduces heat, this helps keep rings free from
carbon buildup, prevents blow-by, decreases emission, and extends oil life.
