CustomMSP said:I should be able to take the tranny apart with it attached to the engine right? Just enough to replace that part. It seems like that would work.
Surprisingly the sqeeking almost stopped after I dumped like a tablespoon full of oil out of the tranny. I think I overfilled it?? The shifting is very notchy now as oppose to when the tranny was a little underfilled.
Thanks!
1.YES
2. If you welded it, it was probably welded incorrectly, or you need to check the shift fork and rubber boot.
