My Turbo Project
Rogue said:
thats ur HP after ur turbo? wow thats not bad... but im sure with time it will improve. i should be around that saturday
Rogue said:
i'm running the MSP ECU. can't really tune that...at all
............oh......yeah scratch that idea then. But dude can't complain with putting down 160 to the ground at 7psi. That's about 190 or so BHP......not bad.....my math is bad so yeah.
He still has the intake...it is somewhere in the mountain of boxes we have left to unpack (new house). :)
I'll try to find it this weekend and clean the filter for you. I'll get some pics, too.
Shadow102 said:
I just did a bunch of matineince work done on the car and got his AC installed and working
*fixed
Thank you so much Korey!!
There's a set of cams for sale that I'm eyeing.... I have the specs to them. Can I get the stock cams re-ground? Are they able to add material to the lobe?
That reminds me that my AC is f0x0red.....
It works 20% of the time... then the AC light goes out and it blows hot air.
Any guesses? (ac compressor clutch maybe?)
on what setting 2 and 3?
And no prob luke that AC staying nice and chilly? i just wanna make sure that those o-rings on the lines are holding good.
mines starting to do that on #2 but only if its hot outside...
this is in the P5 BTW
The A/C is definitely working, but it doesn't get as cold as the A/C in my car...and kind of feels "humid" if that makes sense. But it is SO much better than no A/C!!!
Prodigy said:
2,3,and 4
It always works on 1.
Any ideas?
Yeah that is typical protege AC controls. The go out after a while. seting 2 and 3 are most common but i have seen it done on 4. 1 never goes out though. Mine is intermitant on 2 and sometimes 3. At first with the light blinking i thought it was the system itself but its the actually ellectrical dash unit.
Mine was sometimes intermittant on 2, also. Drove me nuts, 'cause 1 doesn't cool enough, and 3 and 4 are friggen' loud!
I had the A/C control unit quoted from Protege Garage for about $180.
Mind you, this is a new 03+ OEM unit... it supersedes the stock one with the bad circuitry.
I'll just roll the windows down and enjoy 8psi of boost.
It's better than AC. :D
what's it coming out of?
