RenzoMSP said:Im guessing turbohoses HP are the same diameter as hiboost? So i should find silicone couplers that reduce from 2.75-2.5?
Matrix said:(thought) I would suggest that you contact turbohoses to make sure about their HP diameters. But make sure you order from www.siliconeintakes.com as I can assure you that you will not find a better deal anywhere else. Trust me, I've looked.
Yeah... Great prices $$$ (first)Matrix said:(thought) I would suggest that you contact turbohoses to make sure about their HP diameters. But make sure you order from www.siliconeintakes.com as I can assure you that you will not find a better deal anywhere else. Trust me, I've looked.
Th Best!CasopoliS said:
MazdaSpeedSter said:Good question...
I'm going to be running 2 HKS ssqv's as soon as my intercooler and cold pipe get here. 1 on the hot and 1 on the cold, with the relocate. I wonder if this will be worth it. I already have the bov's. the one on the cold pipe is going to be held buy the flange welded on the pipe, the hot side has a special flange. That way, if anything I can cap it off.
CasopoliS said:There is just no point to venting the air for such a low boost application. Its a show-off valve at that point. Sure... the MAF is relocated AFTER the blow off.... meaning it is telling your engine that it is getting less air... but why would you want that? You want your engine to have air if you want power after shifts. Air is good.... I would not vent until 20+ psi.... but until then... the recirculated air will not put too much stress on the turbo or the throttle body plate.
Just my opinion. My car seemed to run better on a dual setup.... though I wanted to recirc 100%... it ran better when I vented half of the air. I wanted to recirc all of it though. I run 18psi on my Legacy and recirculate every last bit of it. It has worked wonderfully for me and it even sounds like a BOV just because I am pushing so much volume. I wish the MSP was like that....
lol well I wish the MSP bottom end could handle 310 HP too.
tallrd said:you posted this at 7:04 am?? You are hardcore Jon!Nevertheless, I appredciate your input. The problem I had when I did recirculate was that "fssfssfss" sound (compressor surge?) when I recirculated the air from my Greddy RS.
How did you accomplish recirc'ing w/out the "fssfssfss?"
CasopoliS said:100% - no. I think everythime I did 100% recirc I got flutter or turkey.
7:04 your time![]()
Dugg E Fresh said:Tallrd,
Have you come to a conclusion yet on whether to continue w/ the dual setup or blow off to the atmosphere?
I'm not near as far along as you, but these are all questions I will eventually have to deal with.
