The effect of the new setup on performance was definitely noticeable. The response time was a bit slower, and it took a bit longer to spool than before. But once it did spool up, the increased pipe size really made a difference. Even while driving around casually, everything seemed to be a bit smoother than before. In my old setup, my BOV was on the cold pipe about 6" from the maf. I didn't have too many problems with it, but when venting between gears, you could definitely tell it was giving the maf trouble (if the air is vented through the BOV too close to the maf, the air has a moment of latency and its noticeable). I still get a lil hesitation between gears in WOT, but its certainly improved with the BOV relocation. Once I get the ssafc in, I'm hoping it'll smooth off those edges.
Another thing I noticed was happening is the engine bay would eventually get heat soaked, the car would start losing performance. When opening the hood to investigate, I noticed its getting a lot hotter than it was before. I realized that now with the all aluminum radiator, it was dissipating heat way better than the oem plastic one. But that extra heat is soaking into my charge piping and killing performance. Also with that big intercooler in the front, its taking away some of air that usually flows through and cools the radiator. I figure the solution to the problem is more air into the engine bay. Radiator air diversion plates help a bit, but after thorough searching for one, I came up with nothing. I got some pics of a few and I feel I can prolly get a flat piece of aluminum and fabricate one myself. Seems a pair of tin snips and a few bends is all it would take. In the meantime, Im still hoping to run into one for sale.
The only other practical way to get more air into the engine bay is a hood scoop. As far as hoods go for MSP, there still seems to be a few to choose from, especially carbon fiber ones. There was one I saw by DG that had a working ram air inlet. It was pretty expensive ($1200), but I really like the way it looks...
But realistically, it wont bring enough air in solve the problem. I also saw an EVO style hood. There were 2 different variations I found (both were around $700-$800):
Im not huge on EVO style hoods on a protg, but this style seems it would be the best to accomplish my goal. I like the way the 1st EVO hood looks more than the 2nd, but the 2nd would bring the most air in. I plan to think on it a bit more before I make a definitive decision. If anyone has any suggestions on other ways to get air in there, Im open to them...
