msp's top speed??
In regards to that ground wire cut idea, just put a switched ground in, that way when you want to haul ass you flip the switch to disconnect the ground, then when you your abs and s*** back just flip the switch back.
~Alex
MSP Top Speed
Hello all, I actually pinned mine at well over 140 mph. The speedometer needle was way past the 140 mark when fuel cut kicked in. I would say I was doing at least 150 or so and still had more pedal left. Of course this was after I had the ECU flashed at Mazda N.A. . Without a governor, I believe that this car could easily do 160 or better considering the power to weight ratio.(glare) (first)
unless you have at least $20K into engine/transmission modifications on your car, I doubt it.. just because of the fact that you'd be pushing 8-9K rpms.
edit: and because of the aerodynamics of the car.. it already produces alot of drag
edit2: damnit adikt! you beat me. :p
sephiroth said:
unless you have at least $20K into engine/transmission modifications on your car, I doubt it.. just because of the fact that you'd be pushing 8-9K rpms...
and the way the air moves over the car...it produces a lot of drag.
