BradC said:VE= (HP*792001.6)/AP*CR*CID*RPM
Max torque is where max VE is, so use that as your RPM (if your car was dyno'd). AP= atmospheric pressure, I am sure you can figure the rest. Found this on http://www.hotrodder.com/Z28_454/math.html ,
so don't yell at me if the math sucks, just trying to help.
Boost (PSI)
0 5 10 15
7 189.84 254.39 318.93 383.48
R 6 162.72 218.04 273.37 328.69
P 5 135.60 181.70 227.81 273.91
M 4 108.48 145.36 182.25 219.13
* 3 81.36 109.02 136.68 164.35
1 2 54.24 72.68 91.12 109.56
k 1 28.13 37.69 47.26 56.82
1 1.34 1.68 2.02
Pressure Multiplier
BlkZoomZoom said:My head flows alittle over 200 on intake and around 195 exhaust.... oh wait, you meant stock...not "stock appearing". lol
flat_black said:Ahh, yes, I almost forgot; I also made these charts to indicate flow rate requirements at various levels of boost... It was a while ago, so I nearly lost them.
Code:Boost (PSI) 0 5 10 15 7 189.84 254.39 318.93 383.48 R 6 162.72 218.04 273.37 328.69 P 5 135.60 181.70 227.81 273.91 M 4 108.48 145.36 182.25 219.13 * 3 81.36 109.02 136.68 164.35 1 2 54.24 72.68 91.12 109.56 k 1 28.13 37.69 47.26 56.82 1 1.34 1.68 2.02 Pressure Multiplier
jeffmsp said:so are ports designed for low to midrange torque production rather then high end zing then right.
TurfBurn said:Geometrically and mathematically our valves and valvetrain is setup correctly. The ports though had some "issues" and the match you have between your manifolds and ports on both sides are critical to flow. But by far the majority of the cost in my port and polish on my head was in getting the exhaust opened up to match my turbo manifold...
