MSP stereo ?'s
I've searched for this and couldn't find anything helpful........so forgive me if this has already been addressed. Is it possible to hook up subs (two 10" in my case) to our MSP system? I would imagine that I'd need to do away with the crappy stock sub. But, is there a way to hook up an amp and my subs to the stock system?
Any info would be great
thanks
-Ian
yes you can. You don't have to take out the factory subs if you don't want to. I would recommend not using the factory bad wires and run your own. Take out the kenwood cd player and on the back are audio outputs. Run a stereo cable from the back of the cd player to the amp in your trunk. Run a power cable from your battery to the amp. On the back of the cd player there a remote power cable, run a wire from there to the amp.
thanks
-Ian
You'll have alot more luck searching the car audio section.
YOu need to run a larger power wire and ground wire suffecient for your new amp. The factory RCAs may not be great but they are functional.
Go to bestbuy or any car audio shop and purchase an amp wiring kit. Each amp kit has the correct wires you need, depending on the wattage of your amp.
hello2000 said:
Go to bestbuy or any car audio shop and purchase an amp wiring kit. Each amp has the correct wires you need, depending on the wattage of your amp.
I think you have a gramatical error in there :D
I could just pull the deck and fined out, but does anyone know if the stock HU has 3 sets of outputs. F/R/S Or is it just sub?
