bayanrabbani
My friend has a 2003.5 MSP with an Injen Cold Air Intake and an HKS Turbo Timer. Since November of last year he said the MSP will jerk violently from about 3200rpm up till 5000rpm+ regardless of the amount of throttle; it will also occassionally idle rough, and also has periodic check engine light stating the Injector Bank 1 is running lean. The problem gets a lot worse when it is cold outside, i.e. it barely happens in the summertime, but in the wintertime it gets really bad. It also gets worse while the turbo timer is on. He said the problem started after 1 of 2 things: he got his first TX inspection done in Nov. 2005, or it could have been when he took it up over 100 under hard acceleration.
He looked at all the vacuum lines and made sure they're tight. After checking all the lines, putting some fuel injector cleaner in the tank, and taking it to the dealer (told him to take off the CAI and put the stock airbox on) it still does the jerking. He loves his MSP, and he really wants it fixed. Any suggestions?
