rods and crank are forged. But the rods are not spec'd for high boost pressuresorangezoom said:no internals are not forged
you are correct sir!Bigg Tim said:So would it be possible to get the MSP software into a MP3 or P5 ecu? Is that what the flash is, a completely new program? I thought it was just some patches.
I just clarified it.1st MP3 in NH said:He said 2 contradicting things, which is right?
Turbo Matty P said:long story short, the rods and pistons are the same factory pieces across the model range. They are not forged. I've seen them first hand....hell I almost caught the rod as it shot out of my block! The point is...if you plan on running higher boost levels and you want the peace of mind that comes with forged internals....DO IT BEFORE THERE IS A PROBLEM. Had i built my block FIRST I wouldn't be driving a new P5 today!!
If you want to beef up the internals all you should really worry about are the pistons, rods, and head gasket. The stock compressions ratio of 9.1:1 is fine for running 15-22psi on that small turbo. If you plan on getting serious (25-30psi) look into dropping down to 8.5:1.
The headgasket would be the first thing I would upgrade for you guys running 9-13psi. Seriously, listen to me...it's cheap and it'll save your motor!!
Sorry bro but a little info is wrong here.Turbo Matty P said:long story short, the rods and pistons are the same factory pieces across the model range. They are not forged. I've seen them first hand....hell I almost caught the rod as it shot out of my block! The point is...if you plan on running higher boost levels and you want the peace of mind that comes with forged internals....DO IT BEFORE THERE IS A PROBLEM. Had i built my block FIRST I wouldn't be driving a new P5 today!!
Turbo Matty P said:anyone been able to get the MP3 flash in the P5?? I wouldn't mind "tipping" for that
Those SVO motors needed something better back then. But now the new ford gaskets are in pretty good shape.Turbo Matty P said:You're correct Nick, the internals are slightly stronger, but not enough to handle what we're talking about doing. The same goes for the headgasket. Mine blew clean apart. If thats considered acceptable then so be it. I would just replace it with an all- copper racing unit that I know will hold over 30psi of boost. I've used them on my SVO motors and had no problems at all.
