normandy2013
Hey folks, just recently in the dead of winter my MSP has a pretty bad issue with sputtering, it sputters lightly while idle, and when the RPM is between 1k-3.5k it sputters heavily, it jerks a bit. My wideband reads 14.5 - 17.5 idle, is that very lean right? Good or bad? and its smells like heavy fuel while idling for more than 5 minutes in the cabin.
I always run .93 octane and usually take advantage of the octane boost by STP...its amazing when doing pulls, recently I just stop using it (budget issue)
I am using Unichip PnP, should I be using MAP A or B?
My vac line is good with the standard of 20 on the boost gauge during idle
Could it be my spark plugs?
MAF?
ECU?
I have a couple CEL that just recently popped up as well, I believe one is
P0660
and I'll get the other code in the morning...
MAF?
ECU?
P0660
