I just want to comment on some things since I've owned both the Corksport SRI/inlet and the Cobb SRI & inlet. I felt a noticeable increase with the CS SRI/inlet compared to just the Cobb SRI (duh) but then when adding the Cobb inlet, it felt similar to the CS. My LTFT"s are slightly lower with the Cobb (probably from the straightener) and there should be a heat advantage with the Cobb since it's all silicone as opposed to metal. Either way, as you said, most SRI's out there should have minimal difference in gains. Obviously the cost advantage goes to the Corksport at this point. PG also is considering making an intake/inlet package that will compete with Corksport's price but include a straightener... something to keep in mind.
Good point John. I recall Ken posting they were working on one. I've been watching to see if he posts anything further about this inlet. I've looked at the PG SRI which is only $150 and includes straighteners welded inside the MAF. I PM'd him for any dyno numbers but didn't get a reply. Probably a mute point anyway.
