Hello,
I have a 2014 CX-5 that has had an internal coolant leak. I'm not sure from where, I have to refill the coolant reservoir every 400 miles. I did a block test that showed negative results, a shop did a coolant pressure test and held pressure, I had the oil analyzed and the results showed coolant in the oil. The engine has significant sludge buildup, and the engine has developed a concerning noise. A loud ticking that is most evident after letting off the accelerator and RPMs are returning to idle. I replaced the VVT solenoid, but that did not fix the ticking issue. While performing the VVT solenoid replacement, I was able to see the condition of the engine under the valve cover. It made me lean towards a full engine replacement. I was wondering if anyone has advice on that process or has done it? I've contacted a few shops and they're all in the $7-9K for a replacement Jasper engine. The car is only worth $7,500 according to KBB and JD power, but I like the car and besides the engine the car is in good condition. I'm on the fence about fixing this car or buying a new one.
Thanks in advance,
Jojo
Thanks in advance,
Jojo
