MS6 Engine Stuff
Ok guys. I've finally decided on a motor swap. Not sure what platform I'll throw in the 6 yet, but I'm ditching the DISI.
Got a bunch of s*** to sell. I listed prices for most of the bigger items. If there's another item I haven't listed feel free to ask me if I have it and offer a price. At this point I guess it's less of a part out and more of a parts bin to select from.
All prices are shipped prices. Also OBO.
Notable parts I have left:
Oil Pan - $60
Power Steering Pump - $85
Alternator - $85
Starter - $85
Water Pump - $45
Oil Pump - $45
Fuel Rail - $45
In Tank Fuel Pump - $45
ABS Module - $65
VVT Actuator - $45
Knock Sensor - $15
MAP Sensor - $15
There's a few other sensors shown in pics & not shown in pics. If you see something or think of anything else you may need (THAT I HAVEN'T ALREADY SOLD) let me know.
Crank Pulley - $20
Tensioner Pulley - $15
Idler Pulley - $15
Timing Chain Guides - $25
Dipstick - $25
Evap Emissions Module - $45
PCV Plate - $15
Fuel Tank - $50 local pick up only
OEM Black Mica Hood - $200 local, $350 shipped. There's mad swirl marks on it and a few spider scratches but those will come out with a solid buff & wax job. But you'd probably be best off filling in the few dings with finishing putty and respraying the hood for cheap. Underside painted black. No ducting. No fire blanket s***.
Parts Sold (I don't have these anymore!!)
Fuel Pump
AWR Tranny Mount
Billet Grille
MAF & Purge Valve Solenoid
Crankshaft
Throttle Body
CPE DP
Cams
Spin On conversion
Stock Valve Cover PCd orange
CP-E Standback V2. Wire in version (no PIP harness)
DashHawk
SU Radiator Hose
SU Power Steering Cap
Redline Hood Struts
N2MB WOT Box
OEM Injectors
A/C Compressor
Denso Iridium ITV24s
Timing Chain Cover
Crank Position Sensor
Cam Sensor
Sensor near Oil Cap
OEM Seats
Engine Block
Head
Pictars:
Found two scratches that are pretty deep. Must have happened while I had it in stored in my garage.
Ding 1. From the bottom side.
Ding 2 from the bottom side. It was really hard to get it visible on the camera. It's not too bad in person but noticeable.
Ding 3 from the top side. This one happened while it was sitting in my garage too.
Well hell, got some wheels I'm trying to get rid of too if anyone local wants them for whatever reason.
17x7.5 et?? dual 5x114.3/5x100 bolt pattern. Sanded ready to prime and paint. $150 for all 4. Local pick up only.
Added OEM front seats and a set of Denso ITV24s.
All items will be shipped out this afternoon. Sorry for the delay. I'll PM tracking numbers once I get them.
Crank Position Sensor, Cam Sensor, Sensor next to oil cap & timing chain cover sold. All tracking numbers sent out.
Bump
I thought I had posted the scoop on it, but I guess I didn't. IM was PnP'd by myself. The welds are patching a hairline crack in the first runner. It's welded up solid now, should have no chance of leaks. The mani is payment pending from a local buddy atm tho.
Intake Mani sold. Head sold.
ATP Boost Cut Defender and MAP sensor added. Most prices lowered.
Bump
