MPNick said:
What about all of your post's where the O2 is pulling fuel? What about the O2 clamps? Preprogramed fuel and timing curves are based on stock air flow limits with very little room for more. The ECU needs to have O2 feedback in order know if it must add or remove fuel. The O2 is not the only part of it but in closed loop when you are only adding fuel with the stock injectors you will be fighting the O2 all of the time.
If it works like you now have posted the O2 is not doing much at all. In the EEC-V car you can get a systen lean or system rich code if you tune to far one way or the other. If the O2 cannot read this you would never have the codes.
Go back a few weeks and read the post's that you made. You will see that the O2 is completely in charge of fuel in closed loop. I am not saying that the post's back then were 1005 right. I would say that a fews weeks later the same person is posting things that are not the same.
In the modern cars the O2 sensors may be NB. They are FR sensors, how do you think OBDII works. We are not talking about old one wire O2 sensors from the early 80s. The new O2s cost up to $500.00. On the Audi turbos there ran lean all of the time. The newer Nissans almost never go into open loop. More and more cars run that way. This is way we have the O2 tuning software. We can get any car to run pig rich in closed loop if we wanted it to.
Thanks again
Later..........Nick
I will comment directly and indirectly to this and other posts regarding this subject.
I think that you are confusing the facts.
Actually there are just too many misconceptions out there and I will try my hardest to clear them up for you.
My prior and current posts are still presenting the same arguement. The O2 sensor in closed loop is the main input used to
control the engine.
The MAF and TPS are used to signify
load . In this application. This together with RPM will allow the ECU to fuel the engine in all sites.
My above post suggests that the stock O2 sensor is used only as a
closed loop tool for an efficient 14.7:1 A/F ratio.
That is fact
In closed loop the sensor will oscillate because the ECU is trying to maintain the ratio NOT the O2. The O2 feedback is used just for that Feedback. If the feedback is not where the ECU wants it to be in that particular drive cycle it will add and subract fuel accordingly.
I have never said that the O2 will pull the fuel directly. It indirectly pulls it via the ECU. The O2 is very powerful in closed loop. Thats all. Very simple.
***Preprogramed fuel and timing curves are based on stock air flow limits with very little room for more. The ECU needs to have O2 feedback in order know if it must add or remove fuel. The O2 is not the only part of it but in closed loop when you are only adding fuel with the stock injectors you will be fighting the O2 all of the time.***
This was your exact post from above.
This is what I have been saying from day 1. I am glad that you are realising the importance of this now. At first in the other threads you weren't "seeing it". As you put it.
This was our argument on the fact that you can only do so much with the MAF value in closed loop. As I have noticed recently you have also mentioned the need to "kick" it into open loop.
If you notice in your previous posts you had mentioned many many times that this didnt need to be done. Any way its done and I'm glad you are now on the right track.
Next,
Your argument about cost and the 4 wire sensors being better than the past sensors. Somewhat true, They are alot better. BUT cost has nothing to do with it. The reason this is true is because they are using a heater circuit to allow the sensor to reach optimal temp. THATS IT. They dont read any differently. The software that is used is telling you that you are running rich or lean. What do I mean by this. Your software in the piggy back is scaling the O2 signal (0-1 volt). It is saying for example that:
.5 is 14.7
.75 is 11:1
1.0 is 8 :1
And so on. The EECV is making its own conclusions based on sample rates it has been programmed to see in a controlled enviroment for a specific application. This cannot be used when tuning a FI vehicle. In fact it can't be used to tune ANY A/F ratio accurately in open loop.
The cross counts the O2 relays will always vary. It varys from many things I mentioned above, like, rpm, load ,tps, etc.
The ECU will continue to pull fuel until the counts go back to "normal" (lamens terms)
So you see the posts made months ago (not weeks) by myself and others are the same and just alot more informative now. I am allowing the enduser to understand why they need management and the kind they need.
You also mention the EECV . Yes the codes are present because it wants to make sure that sensors' inputs and outputs are correctly within parameters. That is how it relearns and troubleshoots for you. AKA Adaptive Strategies.
That is why you need to stay within certain MAF specs in closed loop so open loop mapping makes "sense"
If we didnt have guidelines then we could not properly configure our outputs to fuel and ignite the motor Nick.
If anyhting has changed it seems to be those who were misinformed about the facts. NB sensors work well to help closed loop cruise conditions. To expect it to "save" the day when tuning for performance? Its never going to happen.
