motor mount help
Flightmedic
2006 Mazdaspeed6 GT
Ok I hear a lot of people talking about upgrading mounts on their speed6's so I went to some vendors web sites and was looking to buy one but I found out that there are so many options. Which ones are the best investment. I was thinking I would go with the SU rear bone engine mount and maybe the stiffdiff rear differential brace. Are these all I need or am I missing something?
Theirs a guy on SU. I forget his name right off hand but he is working on getting some stronger rear axels made for the ms6.
2nr had an drivers side rear axle made and is looking to have the other made
he's broken many axles and the drivers side has always been the one to break
as for mounts
you have only one choice when it comes to the trans and passenger side engine mount for the speed 6 - AWR
if you are looking for the rear engine mount, you have chocies
AWR, cp-e, SU
as for the upper rear diff mount, SU makes one and so does cp-e
cp-e just released their severe duty upper diff mount and is the one I'm using
the last mount to replace is the front diff mount, Turbine Tech in Canada is your only choice there.....
cool thanks for the replies. So I think I may go with the 2 cp-e mounts (wish-bone and upper diff) will this be a big improvement or should I just bite the bullet and do the others you mentioned as well?
all of my mounts were replaced one at a time so I did actually notice improvements as each was installed
cp-e
AWR
TT
they all make great mounts and would suggest using them to anyone
the rear diff is now secured
and the engine has no bobble and feels solid through the gears
do you notice any added vibration in the dash or any where else in the car.
i've done stiff mounts on other cars and loved the improvement but hated the added vibration in the cabin at idle.
its a worthwhile trade off though.
