Ya an intercoolers not a bad idea. If i can find a cheap core and pipes than i could just ditch the stock radiator
I thought you already had an fmic.
Yeaaaaa!
Bump just picked up the other cam gear from mazda. Engine is almost done.
i know how you feel. waiting on down pipe so i can get mine going again.
Trading my cam gears for some 600cc injectors. Build should work out nice this time around. Engine bay will be getting re painted next week pictures up soon. Gonna try to clean up the transmission too and maybe paint it to match the block.
What kind of injectors? Finding cam gears for the FS-DE is almost impossible and unless you already have another set then I would highly advise keeping the gears. You can pick up some STI pink (565cc) injectors for next to nothing. Just a word of advise.
Depending on what cams you have you may not need gears. 600cc is borderline too big for injectors if tuned properly.. I run 575's and at 32psi they were at about 80% duty cycle with a rising rate regulator. Anything bigger than that is going to be a b**** to tune your idle.
Look into RC injectors, they're popular with the honda guys so they can be picked up used dirt cheap. i picked my set of RC 750cc for $120 locally.
I didnt have any issue getting it to idle properly with these.
