Monitoring Fuel On Dash Hawk
mazdasp33d
Mazdaspeed 3
what should I be monitoring the fuel psi? cause when i do either short of ltfts it comes up as a percentage. and also what numbers should i expect to see? thanks
I thinks FP Direct Injection is what you want to monitor and you want around 420 at idle and when WOT no less than 1400PSI.
okay cause ive been on this psi on and i get somewhere around the same numbers except in like 1600s at wot
