Mod List Thread
WHAT THE ****!
I was just playing around, then you had to cross that ******* line didn't you!!
Engine:
Forge WGA
Custom FMIC w/ Vibrant IC Core, Relocated MAF
HKS SSQV v3, purple insert VTA
AEM Dryflow filter, custom intake
SLS Catless Midpipe
ZFR6F-11 Spark Plugs
AWR 95 duro rear MM
AWR Pass side MM Inserts
Epoxy filled front MM
Custom Coolant Res
Custom Vac block
Transmission:
Exedy Stage 1 Clutch
Welded LSD
CS Shifter Bushings
Brakes:
SS lines
EBC Green Stuff Front Pads
Suspension:
Spool front Drop springs
Vibrant Front Strut Bar
Wheels/Tires:
RX7 FD wheels, bare alumnium finish
245/45/16 front 225/45/16 rear Ventus RS-2s
Racing Harts as backup set
Appearance:
Exterior:
DG CF OEM Style Hood
Yukidb CF Eyelids
Squinty
Alumnium ADP
Custom Front Plate Mount
6000K Hi/Low HIDs
Shaved Spoiler
Custom 3rd Brake light
Bluebatmobile smoked overlays
Tribute Fender Marker Lenses
Interior:
Dave B Gauge Rings
DG CF Passenger side Dash cover
Snap-On Custom Shift knob
Custom Gauge cluster pod
Electronics:
Garmin Nuvi 350
Kenwood CD player
Prosport Premium Boost Gauge
Greddy Turbo Timer
Waiting To Be Installed:
Medieval Front MM
SS Clutch Line
Wish List:
DG CF Gauge Bezel
Mod list:
Engine:
Eaton M62 "Mr Speed Kit" Customized to fit the FS engine.
WRX 440 Injectors
6.7" Crank Pulley (9.5 PSI)
Greddy RS BOV
JDM Sport Intercooler (27"x7"x2.5"
Apexi 2.5" Airfilter
Headers
Medieval Rear MM
Medieval Front MM
Medieval Passenger MM
Medieval Transmission MM
NGK Spark Plugs
Mobile1 Synthetic 10w30
Optima Red Top
Custom Grounding Kit (4awg)
Billet Coolant overflow
Transmission:
TWM shifter
Corksport Bronzoil Bushings
Kartboy Shifter Bushings
Proper+ Shiftknob
Brakes:
Stock
Suspension:
Tein Super Street Coilovers
GT Spec Lower Tie Bar
GT Spec Front Strut Bar
GT Spec Trunk Cage
GT Spec Trailing Arms
Progress 22mm Sway bar
Ford Escape Front Endlinks
Custom Rear Endlinks
Tires:
Mazdaspeed 6 Stock Rims ( 225/40/18 Bridgestone)
(Race Wheels-SCCA)
Reinforced FD Rims (225/50/16 Dunlop)
-Used with 5mm spacers all around
Exterior::
DG Grill Painted Black
Auto Exe Front Air Dam
Retrofitted Headlights (DS2 Bulbs)
JDM License Plate Tilt Bracket
Rear Skirt Painted Black
Emblems Painted Black
LED License Plate Lights (rear)
Interior:
Corbeau FX1 Pro Seat
Custom Gauge Vent Pod w AEM Wideband AFR
Harness Bar
Corbeau Harness 5pt
Trims Painted Black
Custom Interior Door Wrap
Pioneer Component Set
Pioneer 700w Amp
Pioneer 250w Amp
Shallow 12" MTX Sub w/ Stealth Box
All Interior Lights Converted To LED
Wish List:
PNP Intake Manifold
2.5" Exhaust
Intercooler
M62
FD Rims
Engine Bay
MS6 Rims
Trunk
Interior
ENGINE:
INJEN Cold Air Intake
GT25 Turbo
Mishimoto FMIC
CX Racing Intercooler Piping
HKS Black SSQV2 Blow-Off Valve
ATP Turbo Water/Oil Connectors/Hoses/Fittings
Tom Motorsport Titanium Catback Exhaust
AutoEXE 60MM Big Bore Throttle Body
Mental Addiction Motorsports Cat-Less Midpipe
Corksport 52MM Radiator
Hayden 12" Slim Fans
MSP Flashed ECU
SplitSecond Air Fuel Controller
Perrin Fuel Rail
ProSport Oil Sender Plate
Optima Red Top Battery
AWR 95 Durometer Polyurethane Motor Mounts
Kartboy Polyurethane Exhaust Hangers
NGK Iridium spark plugs
Vibrant Black Vacuum Distribution Block
Black Silicone Vacuum Hoses
NRG CarbonFiber Hood Dampers
NRG Chrome Oil Catch Can
Mazdaspeed Oil Cap
Medieval Aluminum Air Diversion Panel
DRIVETRAIN:
Fidanza Short Shifter
MazdaSpeed Lightweight Flywheel
Kartboy Polyurethane Shifter Bushings
Corksport Bronzeoil bushings
Corksport Stainless Steel Clutch Line
SUSPENSION:
K-Sport Kontrol Pro Coilovers
K-Sport Pillowball Mounts
AWR Adjustable Front Endlinks
AWR Adjustable Rear Endlinks
KMR Front Strut Bar
KMR 4-Pt Ladder Brace
KMR Front Lower Tie Bar
KMR V-Brace
KMR Rear Link Reinforcement Panel
KMR Rear Strut Bar
WHEELS/TIRES:
17x7.5 +45 Rota Slipstreams, Flat Black, Red Lip
Deevo Aluminum LugNuts (Red)
BRAKES:
EBC Drilled & Slotted Front Rotors
HAWK HPS Front Brake Pads
HAWK HPS Rear Brake Pads
EXTERIOR:
DG Motorsports Urethane Front Lip
DG Motorsports CarbonFiber Grille
Mintblue eyelids
TechOne 6000K 55watt HID's
Rockblocker Dark Smoked Headlight Overlays
J-Spec Taillights
FD Front Running Lights (Tinted Black)
Tinted Black Sidemarkers
ProtegeGarage Shorty Antenna
Black painted emblems
INTERIOR:
Tenzo Grey Racing Seats (2)
G-Force Black Harness Belts (2)
Custom Fabricated Harness Bar
ZeroTek Red CarbonFiber Shift Knob
Sparco Drift Black E-Brake Handle
RedLine Goods CarbonFiber Shift Boot
RedLine Goods CarbonFiber E-Brake Boot
RedLine Goods CarbonFiber Armrest Cover
AutoMeter Triple Gauge Pod
SlowShift Triple Gauge Pod
Prosport Amber Air/Fuel guage
Prosport Amber Oil Press guage
Prosport Amber Oil Temp guage
DaveB Gauge Rings
SpeedHut CarbonFiber Gauge Bezel
SLS Performance Aluminum Door Lock Bezel
MazdaSpeed Door Sills
MazdaSpeed Pedals
MazdaSpeed FloorMats
ICE:
Pioneer DEH-P62000BT Receiver
Kicker KS Series 6X8" (Front)
Kicker KS Series 6" (Rear)
SPONSERS:
ProtegeGarage
REPRESENTING:
Team Pro5
Arizona Mazda Club
Protege5.com
ProtegeGarage
K-Sport
Simon Noitalay
Justanothermp5
2002 Mazda Protege 5
--Engine--
*Forged Built Engine*
-OEM Main Bearings
-OEM Rod Bearings
-OEM Headgasket
-ARP Main Studs
-ARP Head Studs
-Pauter Billet Forged Rods
-Wiseco 8.5:1; .020 over
-3-Angle Valve Job
-OEM Valve Seals
*Vibrant Vacuum Block
*CorkSport Front and Rear Engine Mount Inserts
*AWR Side and Transmission Mount Inserts
*Thunder Manifold
*MSP T25 clocked w/ ATP wastegate
*Corksport 2.4" S&J-Pipe
*SLS Performance Catless midpipe
*Megan Racing 2.5" CBE
*Custom 2.75" Alum. Intake w/ K&N Filter
*Relocated MAF
*Modified MAM Sleeper FMIC Piping w/ HKS V1 SSQV BOV
*Mishimoto Z Line Intercooler- Black
*Stainless Steel T Bolts
*Black Silicone Couplers
*P&P 626 Manifold
*Oil/Coolant Supply
-Stock MSP Oil Feed
-Custom Return= -10AN fittings and line to oil pan
-TB Coolant by-pass
-1/4 NPT to -6AN Push-Loc (coolant return)
-1/4" Rubber line (coolant feed)
*Wrinkle Black Valve Cover
*12" Slim Fan (Puller)
*10" Slim Fan (Pusher)
*Cruise Control Delete
*Windshield Washer Reservoir Delete
*EGR Delete
--Interior/Electronics--
*AEM Wideband
*Prosport Electronic Boost Gauge
*SplitSecond AFC V2
*Glowshift Oil Pressure gauge
*Glowshift Oil Sandwich plate
*Single DIN 3 Gauge plate
*Prosport Boost Gauge
*HKS Turbo Timer
*Greddy Counterweight Knob
*DEH-2100IB Pioneer Headunit
*Pioneer 6x8 Rear Speakers
*Custom Wrapped Headliner/ A-pillars/ B-pillars/ Shift boot
*(In the works) Bamboo Flooring Trunk Liner
-Suspension/Brakes/Drivetrain-
*17x7 Mazda MX-5 wheels
- 205/45 Cooper Zeon Tires
*Tokico HP Struts
*Ground Control Sleeves
*Powerslot brakes
*Goodrich SS Brake lines
*EBC Greenstuff pads
*B&M Short Shifter
*Spec Stage 1 Clutch
-Exterior-
*Gloss Black DG Lip
*DIY Black Headlight Housing
*3000K HID Headlights
*OEM Mazda Fog Delete's
*Black Badges/Rear Valence
*OEM Erebuni Carbon Hood
*Smoked Turn Signals
*CX-7 Antenna
*Rear Wiper Delete
im gonna keep this in MOTM format so i can enter easily lol
