Yeh if your fuel pump isn't starting (you should be able to hear the pump going just before you kick the motor over as the microtech runs the thing at 100%) then you're motor wont be running.mazdaspeedwerx said:could that be the reason it does not start? I looked the the manual but did not see the instruction on where it went
FROM MEMORY (and please clarify this with the manual before you go doing it
The details on it will be somewhere in the back of the manual, and are covered as part of the big wiring diagram.
