I dropped the oil pan on my mazda protege yesterday and found a lot of metal shavings in the oil pan. The reason I dropped it is because it was acting like it was locked up, so I started taking out the plugs one at a time and it will crank and run with the #2 plug out of it, but will act like locked up if I put the #2 plug back in it. I was told it was the #2 rod bearings so I dropped the oil pan and pulled all the rod bearing caps and they all looked good. Does anyone have any idea what it could be?
