but you still haven't explained why its all rusty looking
running either strait is stupid. anti-freeze doesn't transfer heat like water does... and water obviously leads to corrosion.... no water probably contributed to blowing the HG.
the problem is the protege's coil packs have a built in igniter, which calls for special electronic controls for them... thats why other aftermarket ignition upgrades like MSD don't work with them... thats why you need a protege specific J&S for it to work on the protege
I'd imagine the aftermarket units follow the same design as stock, assuming they are stock replacements.So, if aftermarket ignition coils (e.g. Bosch) are being used - say with a Microtech - then there is really no need to have a Protege specific Safeguard or whatever the new version is going to be?
Miguel look into getting Evans waterless coolant, it can drop cylinder temparatures by 50 degrees or more and it's 100% coolant surrounding the cylinder at all times !!
would that be NPG or NPG+ one ?
I'm assuming your using it, from reading some info on it this coolant operates in lower pressure then the regular coolant. Looks to me that the coolant system will be in half the pressure compare in case of regular coolant.
any thoughts on that ?
Miguel - keep up the good work![]()
Yeah, NPG+ looks like a safer bet.
I'll go with that next summer when I forge the motor since now I can't empty the engine w/o taking it apart.
How you liking it so far ?
BTW - anyone else wants a J&S w/ 8ch and many other features lmk so we can get good price as well
Miguel where are the updates !!!!!!!!!!!!!
hey, what kind of pistons did u have before? because i have the arias 8.5:1 and i was wondering if i would need to do the same kind of modifying to get them to clear the oil squirters?
Well, there were lot of people that put me and my car down because i paid to get it done in the past,,, but know things have changed in the present and who knows in the future.. This time this bad boy have been done by me. And i feel a little more proud than before and iam sure well be back bigger, better and stronger !!!
