Maxx Mazda
Contributor
- Stock P5
I'd rather have a proper map than rely on the j&s to rein it in for me. The whole idea behind the system is that you should NEVER need it...
Okay so before you became the "haltech guru" it could have been usefull! Especially since you already melted a piston in your previous build!!??
Hahaha... Bro those pistons run for 710, $ 950,
no more Arias, CP or Wiseco Lets see how these bad boys do on my next build..
Not much of an update but well something is something... I went and picked up the head from the Machine shop, came back in perfect shape and ready to be installed, also ordered the TurboXS Knock Light with TurboXS Bosch Knock Sensor i hope if comes this week so i can install everything at once and start tunning the car
the problem is the protege's coil packs have a built in igniter, which calls for special electronic controls for them... thats why other aftermarket ignition upgrades like MSD don't work with them... thats why you need a protege specific J&S for it to work on the protegewell with the power level that is planned for this engine. His window of safe tuning vs destruction is going to be very small. I would be losing sleep over the j&s myself. Shoot, I am already starting to think about it each night in bed. lol
seriously though, what's so hard about getting one? Their basic units should work just fine for your set up. Even though it's not specific to your model, that shouldnt be an issue.... I was just on their website, and it looks like nothing has changed. Have I missed something?
edit: are you running a sequential injection set up? Our engines are batch fire, so individual cylinder control shouldn't be so important.. just a thought..
And, if I had the J&S last spring. It would have saved my engine from it's current failure. An injector rail bolt worked loose, and hopped the #4 injector off the intake manifold at 24.7psi. I'm sure I wouldn't have lost that cylinder if I had the j&s when it happened...
is that head your original factory one? I don't think it should say "FS2" on it!Not much of an update but well something is something... I went and picked up the head from the Machine shop, came back in perfect shape and ready to be installed, also ordered the TurboXS Knock Light with TurboXS Bosch Knock Sensor i hope if comes this week so i can install everything at once and start tunning the car
how much would it be to build my motor with those pistions and rods(five-0)
wow thats beautiful. is that a custom head? whats been done to it?
that's what I thought.... no big deal since its ported... if it wasn't you're screwed because it looks like an earlier FS-DE head which has smaller intake portsBro i dont know all i know Hiboost and TBK Built that head for me and came from Outside USA dont ask me where but definitely not from USA, i think from Argentina or Colombia not sure tho, then they did all of the work to it, bigger valves, etc etc etc..
you need to run more antifreeze in your cooling system... that rust is getting nasty! running straight water is stupid!
i'll remind you that i blew my head gasket and water got contaminated with oil and vise versa, I've never ran water in my car. Solid Anti-Freeze..
then why are all the water galleries all rusty looking?i'll remind you that i blew my head gasket and water got contaminated with oil and vise versa, I've never ran water in my car. Solid Anti-Freeze..
