stars.eg6 said:well if you dont want to do it the easy way this is how it goes.
"The service manual says you can remove it in one piece. To get it out in one piece the instructions say:
1) Remove the rear shock absorber lower bolts
2) Loosen the rear crossmember component installation bolts (6 locations) and lower the rear crossmember component approx. 70 mm {2.8 in.}.
3) Remove the main silencer."
That doesn't sound too bad. Since I'll have the car on a 4 post lift, this should be a snap.
