Hey Everyone,
From my post the other day I have decided to go with putting only the speed3 rear sway in my 2013 5. My car needs new dampers all around and this sent me down a hole. I'm curious to know anyone's thoughts on matching/ miss matching dampers on the front and rear of the car especially considering my rear sway bar. This was brought about because I also would intend to run the FCM/ 5x racing bump stops from the 3/speed3 on the 5 for some extra performance. Below is an email I sent to 5x, but I wanted to pose the question here to get some more opinions:
"I have a 2013 Mazda 5 that is in need of new suspension. It's a DD but coming from miatas and a lightly modded Mazda2 I'd like to tune up my 5 a bit. I ordered a Mazda speed 3 rear sway bar for the car. I was going to do Bilstein B4 shocks all around and give them a bit of help from your bump stop kit since the speed 3 and the 5 take the same parts in this case. I then stumbled across the Koni Special Active line of absorbers. I am wondering if you think that they will play well with your bump stops, especially considering my upgraded rear bar? I am thinking at the very least the Konis would be good/better in the rear because the upgraded sway will impact spring rates and the koni dampers will auto adjust to that rate change as opposed to the B4. I also then get concerned about mixing and matching brands of dampers if it would make the car worse. There are some mentions that the konis are picky about bump stops but your page about the 5x bump stops says they work well with Koni FSD dampers which were the predecessor to the Special Active Series. Thanks for your thoughts on this."
So yeah, I'd like to hear your thoughts on going what dampers will work best for my 5 with the speed 3 rear bar. With the speed3 rear sway should I do Bilsteins up front and special actives in the rear? Will I be okay with all Bilsteins? Is it worth the cash to go all Special Actives? How would the upgraded bump stops play into all this?
Thanks so much!
-J
Thanks so much!
-J
