Mazda of the Month | ENTER NOW for April!
Status
Not open for further replies.
Just a reminder...The...
DEADLINE to ENTER is April 16th '14!!!
The time to enter is now not later, let's see those entries!!!
Maleskimp3
Nate Maleski
2001 Mp3
Mod list
Engine
Paulter Rods
Wiseco Pistons 83.5
ACL Race rod Bearings
PTE 6262
Cometic headgasket
Cometic exhaust gasket
Cleveite Main Bearings
*Block casting cleanup
AWR oil pan
*Port and polished head
*Torque Plate
Super tech dual springs
Super tech Ti retainers
Super tech +1mm Intake Valves
Super tech +1mm exhaust Valves
*Valve shims
SRS cam gears
*Cam sensor pickup
ARP cam tower bolts
ARP cam gear bolts
ARP valve cover bolts
*Water pump Impeller
*Fuel Rail
*Dual PumpIn tank pump holder
x2 Jay Racing PT342 Fuel Pumps
Aeromotive FPR
Golan Fuel Filter
Earls and Vibrant AN Fittings
*Exhaust Manifold
*Full exhaust
*WG dump tube
Tial MVS waste gate
*One wire alternator brackets
Chrome One wire alternator
*Custom boots with MSD wires
NGK plugs
ACT 6puck sprung
Fidanza fly wheel
MSP axles
*Thermal Spacers
*Intake Manifold
ARP intake studs
Vibrant Silicone Couplers
Vibrant T-bolt clamps
*All intake pipes
Tial Q BOV
Green intake filter
Carbon velocity stack
Greddy catch can system with E vac
Jay Racing Vac Block
Holley 75mm Mustang TB
Eat Sleep Race Inter cooler
Modified Crash bumper to fit
Corksport Radiator
Spal Slim fan
Greddy Coolant overflow tank
*Coolant line relocation block
AWR complete engine mount kit
Powder coated almost everything I could think of to powder
Electronics
AEM EMS4
AEM Smart Coils
AEM wideband
AEM oil pressure gauge
AEM true boost
Autometer Tach
Autometer shift light
*Push button start
*Replacement main relay board
Rear ABS sensors for launch control
Dry Cell Battery
Interior
Sparco Evo 2
*Sparco seat mount
Sparco FIA Harness
Momo E brake handle
Momo RACE steering wheel
NRG steering wheel adapter
NRG steering wheel quick detach
*Carbon Laptop stand
CR3 dead man pedal
3 pillar pod
Switch panel for fans, fuel pump, ign, etc...
*5 Point Roll Bar
*Customized rear seats that still fold down with Roll bar.
*Weighted shift knob
*Re worked Short shifter and ball bearing linkage
Exterior
VIS Carbon Hood
Carbon trunk
Carbon Grille
HID lights
Jay Head wastegate dump
Aeroquip hood pins
Vortex generator from STI
ARP fender bolts
CR3 ADP
CR3 radiator mounts
3.5 MSP rear lip
JayRacing Stickers +6 hp
Suspension/Wheels
M&H Slicks 23 1/2"
15" Rota slipstreams
Bridgestone Potenza
Kazera wheels
Yellow Speed Coilovers
Ladder Brace
V brace
Lower tie bar
Megan Racing trailing arms
Progress 21mm rear sway bar
*Sway Bar relocation Brackets
*Rear sub frame mount (CR3)
*Aluminum Lateral arms
*Titanium long bolts for lateral arms
*Front sway bar end links
*Rear sway bar end links
EBC Brakes
Drilled and Slotted Rotors
Anything with "*" are things I've made at JayRacing
Gerald Mugar
Rockeeter would like to change it to mini_FD
99 miata
Fill ER Up by rocketeerbandit, on Flickr
Side Profile by rocketeerbandit, on Flickr
Framed by a Dead Bush by rocketeerbandit, on Flickr
moss miata_ by rocketeerbandit, on Flickr
IMG_0799 by rocketeerbandit, on Flickr
warbird 4 by rocketeerbandit, on Flickr
These are the mods I have currently
Engine: megasquirt 2v.3 built by reverant
Gt2560r dynod at 257 whp and 259 torque at 14lbs.
Flyin miata kit II
Koyo 53 mm aluminum radiator
Mishimoto silicone hoses
Arc radiator cap
Mishimoto slim fans and shroud
ev14 460cc plug and play injectors*fiveo motors ports
190lph walbro
Transmission
Spec 3+ 6 puck sprung clutch
8.9 lb fidanza lightweight flywheel
Mazdaspeed miata complete rear end 4.1 lsd, axles and drive shaft
Suspension
Autoexe 3 pt. Strut bar
Tein flex
Jackson racing sway bars
V8 roadster frame rails
Racing Beat polyurethane end links
Mazdaspeed competition motor mounts
Energy bushing polyurethane differential mounts
Brakes
Ebb green stuff
Exhaust
Rsr ex mag I I-
Exterior
2004 Mazda speed miata face lift
garage vary front lip
Autokonexion v.1 duck bill tail
01+tail lights
Garage star hard top spoiler
Oem hardtop
Demon camber precedo 157.5 -5
Rays black anodized lug nuts
Smoked ebay side markers
Led side marker and license plate lights
Garage vary eyelids
Debadged
fresh paint 12\13
S2k radio receiver and antenna-
Rob ryoku red anodized tow hooks
Dz101 Dunlop tires 195 50 15
Interior
Revlimiter's war birds custom gages
Rs meter gauge
Eunos swarkoski blue horn badge
330 mm deep corn red stitch Nardi wheel
daikei hub
!njoy sun visor deletes
Carbine bronze shifter
10th anniversary shifter surround
pioneer stereo
Polk 6 in. Speakers
65 watt mini amp
aem digital water temp gauge
Ebay gauge surround
01 miata seats "surfboards"
01 door panels
01 black carpet
01 ac face amber lighting
Mazdaspeed door sills
I'm not following you?
Great to know you guys dig the prize...As for pics, remember you can have up to 5 of any kind...If you're low on fresh track shots, how about mixing in some detail shots...Show off your setup / fab work / suspension / garage (with car) etc...Instead of a pic, how about a video..?
Also...This month isn't just for hardcore racers...If you enjoy the occasional track day in your Mazda, then you're welcome to enter as well!
Ps...This month is open to any Motorsports...Autox, track day, rally, off road, drag racing etc..
It would. I actually went to a corvette event that was held in Palm Bay at a community college parking lot where it was held being 20 mons away from my residence. Other options were Orlando or daytona. It was my first event, low key and informational. I borrowed a helmet from one of the corvette owners wives since I have a small head and just went out there to have fun and learn. And the first lesson was to raise the cars suspension travel up a inch or more all around. I plan on getting 225 45 15 rs3 after I burn out the rubber I have on now and trying to find 15x9 et 10 set of tasteful wheels. I purchased a set of autokonexion flares for a wider stance and create a lower center of gravity without hurting performance.
I've done a few local time attack events so ill enter:
1. ilovewheels
2. Korban Corbett
3. 2003.5 mazdaspeed protege
4.
race car pic
AMP Adams Time Attack Mazda Shootout 7-30-13 by jonashaffer, on Flickr
car car small by korbancorbett, on Flickr
ver2 by korbancorbett, on Flickr
cropped by korbancorbett, on Flickr
winglazz-small by korbancorbett, on Flickr
5.
engine:
custom fmic kit
custom intake
footwork:
megan racing coilovers
17x9 rpf1 on 245/40/17
dunlop tires
exterior:
custom fender flairs
interior:
race bucket
one off ipad indash radio
shifter extender
color matched steering wheel
boost/volt gauge/scan gauge
Awesome entries so far but let's see MORE!
As for the deadline...I might extend it IF we can get more of you to enter...Remember the prize this month people ->
From the International Motor Sports Association (IMSA.com)...
(thumb) Hot Pass for Winner and Guest at one of the Winner's choice of TUDOR
Championship races
(thumb) Behind the Scenes Tour including being on the Starting Grid for the
race, Transporter Tours and a visit to Race Control
(thumb) Exclusive Pit Lane access during race
Many thanks to the IMSA | TUDOR United SportsCar Championship for this fantastic prize! (2thumbs)
rally2003
Corey Plotts
2003.5 MSP
Dat Tripod :)
Interior:
-NRG steering wheel
-JBR shift knob
-Kartboy short throw
-Polyurethane shifter bushings
-Sparco EVO (driver side)
-Sparco REV (passenger side)
-Custom carbon fiber radio surround with gauge spots
-Custom carbon fiber shifter bezel
-AutoMeter CF oil pressure gauge
-AutoMeter CF boost pressure gauge
-AEM UEGO wideband
-Driver mod...
Engine:
-Full Vibrant 3' exhaust w/ high flow cat
-Corksport polyurethane exhaust
-12lb battery
-Mishimoto FMIC
-Mishimoto full radiator
-Mishimoto dual 12" fan shroud
-626 ported and polished intake manifold
-Split Second Air Fuel Controller
-SU 60 durometer front motor mount
-SU 60 durometer rear motor mount
-AWR 80 durometerside engine mount
-AWR 80 durometertansmission mount
-JayRacing throttle body thermal spacer
-JayRacing intake manifold thermal spacer
-Aluminum hot and cold pipes
Suspension/Brakes:
-AWR 21.5mm rear sway bar (modified)
-AWR adj. rear endlinks
-AWR adj. front end links
-AWR trailing arms
-AWR coilovers
-450lb Eibach front springs
-600lb Eibach rear springs
-Techna braided brake lines
-Drilled and slotted rotors
-Porterfield race pads
-Energy Suspension rear sway bar bushings (modified)
Exterior:
-DGM carbon fiber hood
-Enkei RPF1 17x9 +22 (front)
-Enkei RPF1 17x7.5 +48 (rear)
-BFGoodrich RS1 255/40/17 (front)
-BFGoodrich RS1 225/45/17 (rear)
-3M Satin white vinyl
Removed:
-Full A/C system
-Power steering and lines to the rack (depowered)
-Stereo and speakers
-Backseats and hardware
-Washer fluid bottle and lines
Status
