cool, thanksfalsedawn said:I would recommend proper brake caliper grease (it's synthetic, and not petroleum based) - anti seize grease is just that - meant to prevent seizing, not lubrication. (hence why it's good on bolts, spark plug threads, between wheel and rotor etc).
You can get little sachets of the stuff from places like autozone for a dollar or so.
You can't really over-lube as any excess will just be pushed out when you re-assemble and make a mess!![]()
gizzard said:Wow. Thanks for the information. So if I take the TSB info to the dealer, they should fix the problem free of charge?
Thanks. Ok, question real quick: You know how we can swivel the "piston" portion of the caliper away from the brakes to inspect / replace pads w/o taking the entire caliper off right? Well, if I did that would I have to compress the piston to get it to fit back over the pads? Thanks.Nomad said:Technically, the term overlube could mean anything so 'd say, don't put some huge amount on it. You don't want there to be a bunch of excess grease to find it's way onto your rotors. Not so great for stopping.
Yes, you can find the brake caliper grease things as well.
My anti seize copper based grease says it resists up to 2000 degrees and can be used on brake assemblies. I also use it on all my reassembly bolts like exhaust, suspension, plugs etc.
That is the dumbest thing that i have heard. Why the hell would you opt for inferior brakes? On top of that opt for a longer stopping distance is dumb as well. You have 1/2 the shoes left because rear drums dont grip for s***. My rear pads lasted 45k miles and then i changed them. I'd rather change the rear pads every 25k miles than be stuck with drums in the rear.macklum said:I opted for the drum brakes and no ABS on my 2001lx for that reasons ,Mazda rear calipers are s*** , I just checked the drums at 137kms and I sill have 1/2 the shoes left .
aMaff said:Thanks. Ok, question real quick: You know how we can swivel the "piston" portion of the caliper away from the brakes to inspect / replace pads w/o taking the entire caliper off right? Well, if I did that would I have to compress the piston to get it to fit back over the pads? Thanks.
Cool, what are u doing? I'm pretty sure u wouldn't have to compress them, but I wanna be sure. Lemme knowNomad said:Yes, I believe you'd be taking out the pin that needs the lube when you do that. I'm doing some brake work this weekend so it's been a while so i can't remember exactly.
The piston will not have to be pressed back in (actually the rears are adjusted with allen screws IIRC) unless you replace the pads with new pads that are thicker than your current ones. If you just swivel out, it will swivel back no problem unless you have a dunce in the driver seat who steps on the brake while you have it out.
