vds hi ...
with the flywheel if you feel gain, but not until this weekend is the competition that can really tell you if it's worth, I'm happy with this modification
the engine damper, try the scion TS, I just modify it a little
coilover that you installed? is the next thing I do after cusco lsd
the reflash was not very aggressive, makes software only allows values to move a little, but if you feel the difference, in the opening of the vvt, the afr was adjusted, the revolution limiter can not move, just remove and I found it very dangerous, so leave it as it was, but worth it as an alternative to get m ore aggressive tuning
and brought back to the dyno my Paiz, you are adjusting and I'll upload it to the bank to see nuemeros
after this weekend i post the photos, not even sleep with the preparations for the race, Today I am installing the clutch of 4 pills without sprints, Eneos 5W30 oil, spark plugs, line and balance and other details that come out
