Max Boost???
14-16 lbs for 5 years!!!!! Stock internals. My afrs are 12-12.5 still running. It's possible you just can't be stupid.
I could of swore I just read a thread about your engine doing south about a year ago.....I know it didn't put a hole in the block but still. Also you might want ot add all your mods to that statement just so everyone knows
Edit: From what I found your mods are the below. I'm ot sure if your running the t25 again or not.
"440's,thunder header, corksport spipe, apex 2.5" catless j-pipe, custom 2.5" cat back, custom intake, ion fmic and a relocated maf.
Edit #2: I don't even know if that list is right because I noticed you had a few of those items for sale...
lol wow this has been debated so many damn times lol its always like half and half. there's half sayin never go over 10psi on stock engine. and the other half says u can. lol well i'm part of the second half. u can def run 12-14psi with supporting mods and a good tune no doubt. but like jdm sam said it really depend on the driver. some people just gotta learn the limits of there cars and some learn the hard way. which sux but it does happen u never really know when ur engine can go. all i can say is good luck lol
i'm running between 8-10psi on a stock block. i never redline my car...or go over 6k rpm's that often...i would like to boost more, but i'm afraid it'd blow. when i put the mbc on, i would hit around 16psi just doing short 3rd gear runs to figure out how to adjust it...the car was NICE around that level...wish i had the rods/pistons to do it!
I have always been a firm believer that the majority of MSPs are incapable of holding boost over 10psi on stock internals, without an excellent tune and supporting mods. Shoving the boost up to 15psi is openly inviting trouble.
However, there are those few 'factory freaks' out there that seem to respond just fine to whatever sort of mod-nonsense you'll throw at them. I think my MSP was one of those. I ripped apart my entire engine bay (EXCEPT for the block), drove the car with a broken WGA twice (which had the boost flirting with 20psi before I caught on and backed off the gas pedal), drove the car with a lean tune for a couple days (long distance Unichip tune FTL), would have to deal with MAF-induced seizures thanks to the MAM FMIC kit (magnumP5 knows what I mean!), blah-blah-blah .. ran about 10.5psi for years, and the engine was still going strong the day my MSP was totaled. With 92K miles on it! And hell, the damn engine still STARTED and RAN the day I went to rip off all my aftermarket parts in the junkyard. I couldn't believe it.
For the masses, though .. I highly advise caution. Unless you really know what you're doing, or are fully prepared to accept the consequences of blowing your engine (amongst other things) -- I would NOT push it too far past 10 or 11 psi. Nothing annoys me more than seeing people whine over blowing their engines when they didn't take the proper steps to safeguard their blocks against it in the first place!
I've done to many of these swaps for people over the years, think most of the times it was a bad line to the actuator and of poor maintenance. I've found bad plugs and filthy oil in almost all the motor swaps I have done. I've gone through close to a dozen motors so far.
Keep the boost low, keep your oil clean, always have clean plugs in it, never cheap out on gas and you may be able to drive your boosted protege for a long time. Sometimes it just happens, most of the time it was neglect by the owner.
blew my motor at 8.5 pounds, if its taking 20 pounds constant im sure its built
**** i'm scared now. I was gonna turn my boost up to 9. WTF MAN! NOw you completely ruined it for me.
I have a FMIC, Perrin Short Ram Intake, Stock BPV and wastegate, stock exhaust, and a SS AFC. How much you guys think i can boost at? SAFELY?!?!
did you read the thread? there are too many factors for someone to just give you an exact PSI. if you cannot afford to replace the engine or if you are concerned in the slightest bit, leave the boost at the stock level.
U can handle 9psi with no prob imho. just keep an eye on ur afr's and keep oil topped off. i don see why u shudn't handle 9psi. i gotta question tho r u guys all runnin the stock t25? for example i'm runnin a gt28rs and i'ge heard its better on the engine to run 10psi+ on that engine compared to the stock turbo since the gt2860rs will be more efficient. just curious about if most of u r basing this on just merely a stock engine wit stock turbo. or just the stock engine itself wit suppotting mods?
he's not bein mean just lettin u know. cuz he is right none of us can say exactly what psi ur engine will hold even regardless of supporting mods. jus cuz my engine holds 12psi for a few years doesn't mean urs will even if we had same mods and tune.
wow you're kinda mean.
Just asking for your opinions guys.
im assuming that was directed at me. it was a serious question, did you read the thread? there have been several posts in here that say whether its a good idea or a bad idea to run higher boost. in the end, its your decision and not one person on this forum can tell you for a fact your engine will or will not blow up at certain HP levels.
also, if you are not the original owner of the car, then you have no idea how the engine has been treated unless you have taken it apart. it may be in perfect condition, or it may be a time bomb. the suggestion of leaving the boost alone if you are concerned is not to be mean, its to warn you that once you start messing with the power output, you run the risk of screwing up your ride.
when i put on my turbo (t25 w/ t28 interals), i was told that 10psi was max regardless as to what size the turbo was...i'll see if i can find the thread.
Yeah see what most those guys are sayin no do not boost 10psi+ on stock internals with a stock tune. ofcourse that is unsafe cuz u do run into fuel cuts etc.. but like i have a mpi piggyback set up. so i been runnin a gt2860rs. check my thread in the sig if u wana know all mods. but its been runnin 12psi-14psi for bout two years no problems ever. So guess therr's really no other answer but to find out lol but be prepared
when people say not to boost past 10 psi they mean on the stock turbo, because hey..the stocker is more than enough to blow our engine so why would we tell you to buy a bigger turbo and just don't boost that over 10 psi?
If u look in the thread that Topher linked. bigger turbo=more efficient, better air flow, and cooler temps. which is better then running same psi the the stock t25 that is less efficient and at 10psi blows hotter air into ur engine which leads to un wanted problems. but honestly there is no right or wrong answer it's just a matter of what ur willing to push. like me i won't dare try 15psi+. maybe it'll hold maybe it won't this is always gonna be a 50/50 discussion. cuz therr are a handful of people blowin up there s*** on stock turbo doin like 9-10psi. and then theres a handfull with bigger turbos pushin 11-12psi for years with not the slightest problem.
(iagree) i'm just tellin you what most people say lol.
Haha yeah i know there's been so many discussions on this. but IMHO with supporting mods and and good tune even with the stock t25 u shud be abble to run 10psi safely. but guess u never really know til u try lol
