MAM Install pics (UPDATED) 90% done!
Looks like they did a great job with the install. Beautiful piece Beau. I'd love to have that setup!
Pat- if you need any help with the MPI don't hesitate to drop me a line.
Hey..you beat me to it!
Same here..i can help!
I have maps good for upto 12psi on ihi turbo.
Chas
hehe yeah Chas is the man. I'm using his maps although they have been slightly moded to fit my setup. Mainly the analog settings.
well, he was stopping on the way home at little beavis' house.... he is going to help Pat out, but I dont know if they got everything hammered out or not.. we got some good maps that got proper AF ratios, and no pinging, but we couldn't rid ourselves of a bucing or hesitation right when the turbo module kicked in. I'm sure someone who has tuned longer than Pat or I have can fix it. and if iirc Litte Beavis has had one for a year or so...
so I hope it went well :)
sometimes it takes the car a day or so to get used to a new map and start behaiving normal. I usually give each adjustment a full day of driving or two before I mess with it again.
ARGH. i'm ready to toss that damn turbo module. Under heavier load, it throws so much fuel it jerks you in your seat (HUGE jerk). Little beavis and I couldn't figure the damn module out. We did tuning, but the module is being dumb and jerking. After it does kick in, my ratios are good.
Beavis has MPI with injectors and fuel clamp- DROOL. no bucking at all. I loved it.
You have to tune that out man. I have the setup that Nick say's to do and I do not have any bucking. I have the fuel cal at like 2 and zero's where the module comes on and then .25 in the AEng temp column. So there is a bit more to do, but it does get better. Don't be affraid to lean it out when the module comes on.
Yeah..you have to look at the Aengine tem scale and see where you hit boost..(what box) than you pull fuel in that box it elimante..the bucking (stumble)
I had same problem..
Why don't u use my maps? They should work!
Chas
