Quick update. Gave Logan at Defined Autoworks a call to check on the status of the exhaust manifold. Everything's just about ready; just waiting on a SS flange from Racing Beat (they were backordered). *Excited*
I'll also pose another discussion topic: RX-8 rotating assembly. I have the rotating assembly from my previous engine: eccentric shaft, rotors (9.7:1 compression), and stationary gears. An option I have is to replace the eccentric shaft and/or stationary gears from an RX-8. The benefits are the RX-8 eccentric shaft is ~0.5 lbs lighter and the stationary gears are supposedly hardened, three-window types and they are a matched set (eccentric shaft clearance). The only downsides involve a nonexistent o-ring seal groove on the rear stationary gear (must use sealant or machine a groove in the RX-8 gear) and an oil galley in the rear iron (must modify rear iron). The other aspect is cost as I already have a perfectly fine eccentric shaft and stationary gears. The RX-8 stuff would be about ~$500 total. Technically I wouldn't have to balance the rotating assembly since the eccentic shaft is balanced to itself, I'd be using matching front/rear counterweights to my rotors and I'm planning on keeping the redline at 9000 RPM (max on tachometer). However, if I got the RX-8 stuff I'm considering balancing the assembly anyway in case I want/need to wind the engine to 10,000+ RPM. Balancing is about another $300. So, is ~$800 extra worth -0.5 lbs in weight, stronger and better lubricating stationary gears and a perfectly balanced rotating assembly?
