fishdonotbounce
Registered Zombie
- 08.5 CWP Speed3
OMP WRC seat and brackets:
Ummm, you sir are not going ANYWHERE once you are in those seats haha.
Yep, this is what I plan on doing. The unit I purchased is supposed to also come with a DVD so I'll see how that is. I have been reading up on welding lately and talking to some more experienced folk. What you said about the sheet metal is exactly what a co-worker mentioned as well. My only quesiton for you is how did you have your amperage set? When welding thicker metal to sheet metal everything I've read/heard has said to use the lowest setting/sheet metal setting. I've also already picked up an auto-darkening helmet. The only things I haven't picked up are some extra wire (will be running gas), some spoons (need to patch some holes in the floor pan where spot welds were) and MIG pliers.I can't emphasize enough to practice before you start welding, especially if you're new to it. An auto darkening helmet can make all the difference, too. I've been meaning to get one for a while, now. There are plenty of great vids on youtube (and even more terrible vids, as everyone with a welder fancies themselves a master fabber) Your seat mounts are a very important part of the safety equipment, and the last thing you want are crappy welds jeopardizing you or your passenger.
I got some experience attaching 1/8" to sheet metal a few weeks ago, and [at least for my skill level] it's tricky business. I got the best results striking the arc on the 1/8th, letting it pool a bit, and then dragging it onto the sheet metal just enough to get it on, and then stopping. If I tried to do any more than that, it would blow a hole in the sheet metal, and that's a mess to patch up. Let it cool a few seconds, and do another right next to it. Then after 5-10 of those, take a break and let it cool, or start from the other end. You want to get it all tacked in first so it has less chance to warp.
I'm not familiar with the output of the 120v units. I'd guess about 100-130 amps? Are you going to be running gas or flux?
Gee, thanks for the confidenceYou will if the bracket seperates from the car when a weld brakes.
I can tell u from personal experience since i have cut one of these cars in half that the front seat mounting points are definitely structural, but u could get away with cutting them out and welding in a brace ir crossbar!Thanks, let me know!
Nope, no sliders. Just side mount brackets. The bottom of the seat sits about 1/2" off the brackets so I could technically drill out the drear holes 1/2" but I don't know if that's safe or legal, LOL.
Ah no 22V in my garage and no easy way to get it there
Here are some pictures for you guys...
Aeromotive FPR:
Sparco 345 wheel (temporarily installed in this picture):
Seat in the car. It actually fits really well; it's just too tall.
Here's what I've got to work with under the carpet:
In typical unibody fashion nothing is level or flat. The piece running from the door to the transmission tunnel with the holes in it is the forward mount for the stock seat. I've read people say it's structural and it's not structural so I don't know. It is boxed in, but the metal is 20 ga at best so I don't know how much stiffness it's offering (I could calculate this). The rear culprits are the rear mounts as they determine where my head goes. Rear right is the limited case and by removing that altogether I gain about 1".
If I had a welder, my plan would be to first cut out the right rear mount. I would then cut down the left rear mount so it was level with the right rear. Next, I would notch out the front mount so it's level with the two rear mounts. I would then run 1/8" or 3/16" flat stock to connect the rear mounts and re-box the front in with the same. I would then have front and rear mounting surfaces that are flat and level and the lowest possible without modifying the floorpan.
Cheap idea is to just cut out the rear mounts and leave the front mount and mount the backets on an angle. I would have to use a spacer on the left rear mount. I have plenty of adjustability in the seat angle so that's not a concern. Again, it's safety and legality.
EDIT: Oh yeah, I got a call from the shop yesterday about my intake manifold. They are supposed to have the flanges in tonight and once they come in they're going to get right to work on the IM.
Preheating is your friend with welding!
U can get away with stitch welds and then pulling a bead for inch segments after the metal is warmed up.
s***, u could use a cigarette lighter if u dont mind burning yourself.Does propane get hot enough for that, or do you need oxy-acet?
It's funny something .020" thick can be considered structural. The wonders of hollow beams...I can tell u from personal experience since i have cut one of these cars in half that the front seat mounting points are definitely structural, but u could get away with cutting them out and welding in a brace ir crossbar!
The rears are solid, but are just a bunch of layers of sheetmetal pinched together with a nut welded to them. Trust me, if it takes two sawzall blades to cut through one rear mount, theyre solid.
U could just run plating with a nut welded to the bottom side for these. Thats all the factory does.
Other than that a piece of 1x1 square tubing to box your floor would be sufficient!
Goddamn i wish u were closer so i could do some fab on ur car!
So basically tack all the way around until there are ~1" gaps between the tacks and then pull a bead to close the gaps?Preheating is your friend with welding!
The gauges are Marshall Instruments. They're all electric with a 270 degree sweep angle and they perform the ever-loved "start up ceremony". They also have peak recall and warning features accessed via a remote button (mine are where the AAS switch was located). They come in any combination of black and white faces with black and silver bezels. All that for <$100.wut kind of gauges are they? i like it
So is this done while stitch welding, while filling the 1" gaps or both? I have a relatively small butane torch so heating large areas and keeping them hot will be difficult.s***, u could use a cigarette lighter if u dont mind burning yourself.
The idea is to heat the strip of metal to creats better bond.
If u do small patches, then the heat will spread rapidly and stay hot for quite some time so if u bridge the gap between welds it will heat in between each spot and make the metal more efficient to work with!
Wow, talk about your markup... You may be better off calling them directly and seeing what they can do. The prices have gone up a little it seems: ~$110 for oil pressure and oil temperature and ~$100 for water temperature. That's still not too bad all things considered.how in the world did u get it for 100? i c they are like 160 each.,.,.
Got it. I've got an old treadmill bracket thing I've stripped and cut up I'm going to use for practice. I'm going to try to put it back together and see how it looks in the end. It's not sheet metal (I don't have any iron or steel sheet lying around) but it's a start. It's probably .060" thick so kind of in the middle of what I'll be welding. I think I'm going to start a welding thread.Yes, do hot tack welds and then stitch in between.
U can see how the heat transfers through the metal and how long it takes to completely cool.
When im welding on my truck the welds r still cooling hours later. U can see and hear pops and tinging sounds even after uts cool to the touch...
U will be fine welding the brackets in even if u bubble gum weld them, but i would practice a lot before i attacked them though!
Get used to welding thin metal first and u will be golden
Yep, we've spoken via PM a few times on this.Jon I am not sure if you saw it but there is a new guy (Troy or Tony @flatlander...) in Dayton that has fab skillz. Maybe you guys can get together on this.
