mymmeryloss
- 13bT Mazda B2600i
Looks like a lot of fun to me!
This has all certainly been a learning experience. I finally realized last night that I've been underestimating the power to weld just about everything. As a result I went over all the seams again with my welder at pretty much the highest setting. It certainly isn't pretty but nothing is going anywhere and at least everything will be hidden. All that's left now is to grind down the welds on the mounting surface and the seat goes in! I'll try to snap a few shots of everything together. Next on the list:Looks like a lot of fun to me!
I was going to use the leftover 16 game sheet I have to make something like the tiedowns Odyssey sells (full wrap). What was wrong about using 1/8 flat stock? The ETX18L is an AGM battery so I'm not worried about it leaking or anything.What do you plan on using for the battery tray? You wouldn't believe how much crap I got for using some 1/8" stock...
Most guys use the stock seat anchors but I'm a little shorter than average and I definitely like being closer to the wheel than most so I'm worried they may be a little too far back (I'll confirm the angle tonight). The thing about the distance (width) from the seat is from reading harness mounting instructions from G-Force and Schroth. Both of them state the lap belt anchor points should be separated by a distance equal to the driver's pelvis or at least no wider than the seat itself. The stock anchor points violate this.What do other FC guys do for the belt mounting points?
Yeah, I'll definitely be going with the "snap-in" mounting points for the lap and anti-submarine belts.Jon you may want to try to make your lap belt anchors so that they pivot. That way if you do have a crash the belts will move with you and won't tear. It is hard to explain, just research Dale Earnhardt's crash to see what I am talking about. The lower mounts in Nascar cars all used to be solid mount and after they studied his accident they found that a pivoting mount is far superior. Nascar even changed the rule book and made it mandatory.
If I had a harness I'd install everything and see how it goes. I don't want to buy a harness, which only has a 2-year "life", only to have it sit in the car for a year. I'll have to make a substitute in the meantime.Okay, I see the dilemma now. I'm not sure how to help without being there to see it and weigh options, though.
PM sent!Jon I have a set of old belts that you can have they are Simpson belts about 10 yrs. old.
Yep, 90% of this battery tray has been made the old school way - hack saw and manual forming with a vice and hammer. It's certainly not perfect but once finished up and painted it shouldn't look too bad.The battery cage looks awesome! Did you bend the 16ga in a vice?
