Long post...
For some reason I had in mind that you were going with something more 'aggressive' than a 4.3 rear end. Did plans change or is my memory failing me?
The goal was 4.30:1 all along. It's only like a 200 RPM increase over what's in there right now but it's the easiest/least expensive/most readily available swap. I think Mazdatrix actually has 4.875:1 and 5.12:1 ratios available but they're ~$1000 and require you to send in you current ring and pinion. I paid $350 for an extra carrier, viscous LSD and 4.30:1 ring and pinion.
I'm basically working my way forward. After an aluminum driveshaft my next project is to swap in the gears from a '94-97 1.8L Miata as the ratios are closer than the RX-7's. Along with a new clutch and aluminum flywheel I should have a pretty good setup for road courses without having touched the engine.
So I made a little more progress today. Picked up some red lock-tite and with the aid of a vice and some clever tightening of the ring gear bolts I was able to mate the ring gear to the Miata LSD.
And after fighting with the carrier for about 15 minutes (the whole assembly weights about 65 lbs) the new differential is in.
All the white marks you see are paint marks so I could keep everything in the same location so hopefully the backlash isn't out by too much. The bolts on the bearing caps are only hand-tight as they must be torqued such that the distance between two reference points meets Mazda's specifications. Along with setting the final backlash, this is something a shop will have to help with as I don't have a set of dial calipers large enough.
In other news I was finally able to sell my Sparco Torino II's. However, putting the stock seat back in ending up being a job requiring retapping the mounting holes. Now that all that is done I'm left to decide what seats to replace the Torino's.
I'm looking for something with a fixed-back, fiberglass shell, FIA-approved, 5/6-point harness ready and as small and lightweight as possible. The options I'm currently considering:
Sparco Evo (most common)
Sparco Rev Plus (smallest)
Sparco Corsa (recommended by a friend, cheapest)
RaceTech RT1000 (lightest, also recommended)
Cobra Suzuka Pro (really neat looking design)
May go with a roll bar first as I will need that and a harness before installing any new seat.
